The best location for an electric water pump SBC V8 conversion, The best location for an electric water pump SBC V8 conversion |
BRAVE_HELIOS |
Apr 22 2017, 10:06 AM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
Hey all,
Inching closer to going electric on my V8 conversion car. Right now; going through the process of cleaning out radiator and water passages/block with ThermoCure, then Prestone citric acid flush. Assuming I get a really clean system but not fix the run hot situation; I will go electric. Where is the best place to mount the electric pump? It would seem that the easiest way to go in my case is with this: http://www.jegs.com/i/JEGS-Performance-Pro.../50930/10002/-1 It a 50 GPM unit that should bolt right up to the Renegade remote water pump housing already in place in my car on the lower left hand side of the engine... that is assuming there is enough clearance between the water pump and the firewall. Would this work? I have heard stories going back and forth about mounting the pump by the radiator or by the engine. |
914GT |
Apr 25 2017, 08:10 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Here's the timing mark setup on my engine. The orange mark on the balancer is at TDC and 0 degrees on the timing pointer. It would be nice to have it lower but I can still easily see it from under the car.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i216.photobucket.com-2923-1493172655.1.jpg) |
BRAVE_HELIOS |
Apr 26 2017, 08:55 AM
Here's the timing mark setup on my engine. The orange mark on the balancer is at TDC and 0 degrees on the timing pointer. It would be nice to have it lower but I can still easily see it from under the car. (IMG:http://www.914world.com/bbs2/uploads_offsite/i216.photobucket.com-2923-1493172655.1.jpg) Awesome! But it looks like the engine has to come out in order for me to do this... that's a lot of work :-)! |
Lo-Fi Version | Time is now: 17th May 2024 - 03:26 PM |
