The best location for an electric water pump SBC V8 conversion, The best location for an electric water pump SBC V8 conversion |
BRAVE_HELIOS |
Apr 22 2017, 10:06 AM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
Hey all,
Inching closer to going electric on my V8 conversion car. Right now; going through the process of cleaning out radiator and water passages/block with ThermoCure, then Prestone citric acid flush. Assuming I get a really clean system but not fix the run hot situation; I will go electric. Where is the best place to mount the electric pump? It would seem that the easiest way to go in my case is with this: http://www.jegs.com/i/JEGS-Performance-Pro.../50930/10002/-1 It a 50 GPM unit that should bolt right up to the Renegade remote water pump housing already in place in my car on the lower left hand side of the engine... that is assuming there is enough clearance between the water pump and the firewall. Would this work? I have heard stories going back and forth about mounting the pump by the radiator or by the engine. |
dwillouby |
Apr 27 2017, 06:33 AM
Member Group: Members Posts: 392 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
Glad I saw this! I am going to order this pump as I currently have the Renagade setup.
Mine seems to cool fine but the engine heat soaks when shut down. I want the use the electric pump to run after the engine stops and circulate till temps come down. I was going to try the Davies Craig pump but have to rework things. I will sell this pump(new in box) to buy the other. David |
BIGKAT_83 |
Apr 27 2017, 06:46 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Glad I saw this! I am going to order this pump as I currently have the Renagade setup. Mine seems to cool fine but the engine heat soaks when shut down. I want the use the electric pump to run after the engine stops and circulate till temps come down. I was going to try the Davies Craig pump but have to rework things. I will sell this pump(new in box) to buy the other. David This will answer a few questions about which cools better belt driven or electric. Interested to see if you see any difference in the cooling when running. I'm thinking of going with a electric pump just to free up space to mount a ac compressor. Bob |
Lo-Fi Version | Time is now: 17th May 2024 - 04:43 PM |
