The best location for an electric water pump SBC V8 conversion, The best location for an electric water pump SBC V8 conversion |
BRAVE_HELIOS |
Apr 22 2017, 10:06 AM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
Hey all,
Inching closer to going electric on my V8 conversion car. Right now; going through the process of cleaning out radiator and water passages/block with ThermoCure, then Prestone citric acid flush. Assuming I get a really clean system but not fix the run hot situation; I will go electric. Where is the best place to mount the electric pump? It would seem that the easiest way to go in my case is with this: http://www.jegs.com/i/JEGS-Performance-Pro.../50930/10002/-1 It a 50 GPM unit that should bolt right up to the Renegade remote water pump housing already in place in my car on the lower left hand side of the engine... that is assuming there is enough clearance between the water pump and the firewall. Would this work? I have heard stories going back and forth about mounting the pump by the radiator or by the engine. |
burton73 |
Apr 27 2017, 10:50 AM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Thanks for the lead on Davies Craig pump I looked them up on the web.
It sure looks trick. Davies Craig DC-8870 The EWP 130 is made of aluminum with AN fittings. Not sure what model would work best for SBC and 914 layouts but I guess this is it. $465. For the kit with controller. Another $114. For the SBC set up on the engine. Davies Craig DC-0444 - Davies Craig Digital Thermatic Fan Switch Kits . $77. More Not sure if that is it but the full boat is looks like it would be like it is $656. Not cheap but if it works perfect? Bob B |
Lo-Fi Version | Time is now: 17th May 2024 - 02:56 PM |
