The best location for an electric water pump SBC V8 conversion, The best location for an electric water pump SBC V8 conversion |
BRAVE_HELIOS |
Apr 22 2017, 10:06 AM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
Hey all,
Inching closer to going electric on my V8 conversion car. Right now; going through the process of cleaning out radiator and water passages/block with ThermoCure, then Prestone citric acid flush. Assuming I get a really clean system but not fix the run hot situation; I will go electric. Where is the best place to mount the electric pump? It would seem that the easiest way to go in my case is with this: http://www.jegs.com/i/JEGS-Performance-Pro.../50930/10002/-1 It a 50 GPM unit that should bolt right up to the Renegade remote water pump housing already in place in my car on the lower left hand side of the engine... that is assuming there is enough clearance between the water pump and the firewall. Would this work? I have heard stories going back and forth about mounting the pump by the radiator or by the engine. |
Andyrew |
May 4 2017, 09:58 PM
2 port tanks dont constantly purge the trapped air. They simply have a line that holds water, and then another line for overflow. Thats why the 3 port VW tank is optimal and what you see in every modern vehicle.
BRAVE_HELIOS |
May 4 2017, 10:12 PM
2 port tanks dont constantly purge the trapped air. They simply have a line that holds water, and then another line for overflow. Thats why the 3 port VW tank is optimal and what you see in every modern vehicle. Well, that's good news. Can you tell me if you believe mine is connected correctly by looking at the pictures? I will try to find a new 3 port tank that takes a standard pressure cap. |
Andyrew |
May 5 2017, 08:51 AM
2 port tanks dont constantly purge the trapped air. They simply have a line that holds water, and then another line for overflow. Thats why the 3 port VW tank is optimal and what you see in every modern vehicle. Well, that's good news. Can you tell me if you believe mine is connected correctly by looking at the pictures? I will try to find a new 3 port tank that takes a standard pressure cap. Yes it does look correct. The small line is the high HOT side. Should be the highest line in your system. The big lower line is the return to cold side. Feeding into the water pump works perfect. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:36 PM |
