The best location for an electric water pump SBC V8 conversion, The best location for an electric water pump SBC V8 conversion |
BRAVE_HELIOS |
Apr 22 2017, 10:06 AM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
Hey all,
Inching closer to going electric on my V8 conversion car. Right now; going through the process of cleaning out radiator and water passages/block with ThermoCure, then Prestone citric acid flush. Assuming I get a really clean system but not fix the run hot situation; I will go electric. Where is the best place to mount the electric pump? It would seem that the easiest way to go in my case is with this: http://www.jegs.com/i/JEGS-Performance-Pro.../50930/10002/-1 It a 50 GPM unit that should bolt right up to the Renegade remote water pump housing already in place in my car on the lower left hand side of the engine... that is assuming there is enough clearance between the water pump and the firewall. Would this work? I have heard stories going back and forth about mounting the pump by the radiator or by the engine. |
BRAVE_HELIOS |
May 5 2017, 11:25 AM
Was reading a Chevy forum about running hot issues but only when driving (at speed) and someone mentioned that perhaps the pump is spinning in the wrong direction? As in; the incorrect pump was purchased for the application?
My remote pump is mounted on the left sideā¦ opposite of what the Renegade manual shows to do. But it seems to me that it should not matter which side the pump is mounted as the rotation of the pump will be the same. Is this correct? What about might there be different BB Chrysler pumps for different rotations? How would I test this? This info came from here: http://www.chevytalk.org/fusionbb/showtopic.php?tid/58316/ |
Lo-Fi Version | Time is now: 17th May 2024 - 02:08 PM |
