High Mounted 3rd Brake Strobe Light, A few pics, video and contacts, $7.94 total! |
oakdalecurtis |
Apr 26 2017, 11:03 AM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Finally attached an LED high mount 3rd brake light. Added a strobe module to make it really pop.
Here's a short video of it in action. If you watch it in slow mo, you can see the LED lights come on significantly before the car's incandescent brake light bulbs. https://www.youtube.com/watch?v=TaQ6msHbFbA I drilled holes in the LED side mounts so I could use small screws to attach it to the underside of the targa bar instead of just the sticky tape on it. The small holes in the curved mounts' exterior allow screwdriver access to the screws inside the mount. I had to remove the engine lid to allow my drill to fit under the targa bar to drill the small pilot holes for the mounting screws. I ran the thin LED dual wire lead up through another small hole drilled through the LED mount and into the targa bar. Then the wire goes out through a small hole drilled under the rear targa bar chrome trim. After adding a dual wire extension, I ran the wire along under the rear targa trim to the edge trim, then down under that piece. I got the wire into the engine bay through a small downward hole under the side trim and through another small hole in the engine bay side near the trunk hinge attachment point. From there it was easy to follow the existing wire harness back to the brake light connection point. I put the strobe module in-line right there. Do not ground the negative from the LED light before reaching the strobe module since the module needs both positive and negative wires in and out. Ground the negative lead coming out of the strobe module. Finally, using a piggy back connector finishes the connection to the brake light lead without cutting any harness's. Btw, here's a link to the LED light at Amazon for $1.85 and free shipping! Don't know how the can do that! http://www.ebay.com/itm/Red-14-LED-Car-Aut...Nv4&vxp=mtr And here's a link to the strobe module for $6.09 and free shipping. https://www.amazon.com/CARCHET-Strobe-Contr...e/dp/B00I4J35HY A little wire and $7.94 and you're in business! |
North Coast Jim |
May 3 2020, 10:15 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Here's mine. I live is a Sumer tourist area and although I don't have first hand knowledge I'm sure there are a few impaired drivers on the road. Found these at Walmart of all places in a 2 pack. Gave the other light to OLAF who did the same mounting. Double sticky 3M holds it in place on the backside of the Targa trim. No need to remove it when I take the top off. Routed the wires under the trim and exited into the engine compartment. Butyl from the windshield install was used to hold the wiring in place. No glare and no rearward visibility issues.
Would love to locate a module to make it flash a couple of times before staying on. Any inputs folks |
anderssj |
May 3 2020, 11:50 AM
Dog is my copilot... Group: Members Posts: 1,656 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
Here's mine. I live is a Sumer tourist area and although I don't have first hand knowledge I'm sure there are a few impaired drivers on the road. Found these at Walmart of all places in a 2 pack. Gave the other light to OLAF who did the same mounting. Double sticky 3M holds it in place on the backside of the Targa trim. No need to remove it when I take the top off. Routed the wires under the trim and exited into the engine compartment. Butyl from the windshield install was used to hold the wiring in place. No glare and no rearward visibility issues. Would love to locate a module to make it flash a couple of times before staying on. Any inputs folks LSC-400A at www.superbrightleds.com--I've had good luck with it. I like that it stays steady after the initial pulses. Makes it a little easier on the person stopped behind you. You can find it here: https://www.superbrightleds.com/moreinfo/st..._waApQkEALw_wcB There's a video of it about half way down the right side of the page. Hope this helps! Steve A- |
Lo-Fi Version | Time is now: 18th May 2024 - 04:26 AM |
