Alternatives to engine lid torsion bars, Show me what you did |
john77 |
May 1 2017, 04:00 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
My lid alignment was a mess so I inspected the hinge mounts and found both had cracked welds. I re-welded them, put the lid back on, and the alignment was still a mess.
It's a GT style lid and I figured the force of the torsion bars was too much causing it to twist when fully shut, so I removed them and it fits perfectly. Only problem is, now it won't stay open on its own. Anyone have an ingenious solution to this? Simple metal prop attached to the lid? Small shock? Hydraulic air lift set up with nitrous oxide? Thanks John |
Marv's3.6six |
May 1 2017, 08:55 PM
Actual member 7" Group: Members Posts: 695 Joined: 22-November 04 From: Huntington Beach, Ca. Member No.: 3,165 Region Association: Southern California |
It's a GT style lid and I figured the force of the torsion bars was too much causing it to twist when fully shut, so I removed them and it fits perfectly. Only problem is, now it won't stay open on its own. The GT style lid is very light weight.... so with the standard 2 torsion springs it way over powers the lid. I found using just one of the torsion springs was sufficient. The GT lid is also pretty flimsy so it is easy to twist the lid itself to make it line up. Mine was easy peasy. |
porschetub |
May 2 2017, 03:25 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
It's a GT style lid and I figured the force of the torsion bars was too much causing it to twist when fully shut, so I removed them and it fits perfectly. Only problem is, now it won't stay open on its own. The GT style lid is very light weight.... so with the standard 2 torsion springs it way over powers the lid. I found using just one of the torsion springs was sufficient. The GT lid is also pretty flimsy so it is easy to twist the lid itself to make it line up. Mine was easy peasy. Good info,would one torsion bar be enough for a standard six conversion lid ? i.e. less rain tray etc. The gas strut is a solution but it does intrude into the engine space somewhat and its about finding the right one...too much tension and the lid twists as mentioned. |
Lo-Fi Version | Time is now: 19th May 2024 - 01:43 AM |
