Under body air deflector, Source? |
Dtjaden |
May 1 2017, 09:37 PM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
My car is missing the under body air deflectors at the front of the engine compartment. I haven't been able to find a source other than AA that wants $30 each for their reproduction. Does anyone have a source for these? I didn't see them at 914Rubber.
The other option would be to make replacements from aluminum sheet if someone has the dimensions. |
Larmo63 |
May 1 2017, 09:40 PM
Make them with hard rubber and aluminum L metal?
Krieger |
May 1 2017, 09:52 PM
Advanced Member Group: Members Posts: 4,718 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Put a WTB add in the classifieds.
GaroldShaffer |
May 2 2017, 06:43 AM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
My car is missing the under body air deflectors at the front of the engine compartment. I haven't been able to find a source other than AA that wants $30 each for their reproduction. Does anyone have a source for these? I didn't see them at 914Rubber. The other option would be to make replacements from aluminum sheet if someone has the dimensions. (IMG:style_emoticons/default/bye1.gif) PM sent. |
VaccaRabite |
May 2 2017, 12:25 PM
En Garde! Group: Admin Posts: 13,446 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
You don't want to make them from Aluminum. These things scrape off the ground from time to time, so you want something that will spring back into shape after being deformed in a ground strike.
Zach |
May 2 2017, 12:43 PM
914-6 GT in waiting Group: Members Posts: 19,280 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Buy them from Garold.
RickS |
May 2 2017, 11:37 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
I made mine from some spare copper sheeting. Even though the car is lowered, I have not had any ground strikes. You could make them out of tin, or what have you.
Mikey914 |
May 3 2017, 09:45 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I can make these from ABS is someone can drop me some samples (they get theirs back + new ones). I have been contemplating these for some time. the problem was with the catalyzed plastic it was too brittle. If we go to hard tooling my cost is greater, but we have a better selection of material.
Factor made this the way they did for a reason. There are some unique design features on these that make them durable and have a seam that is designed to tear before doing damage to the welded seam. |
Lo-Fi Version | Time is now: 22nd May 2024 - 08:23 PM |
