Transmission cooler Help..., Not sure where to Tap |
slivel |
May 10 2005, 11:08 AM
Old car....... older driver Group: Members Posts: 508 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
This is what I did. It fits nicely under the bracket.
joea9146 |
May 10 2005, 11:36 AM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
What size u using ? |
slivel |
May 10 2005, 12:54 PM
It is the stock plug with a 3/8 inch hole drilled in it. Then weld on a steel elbow with the AN size of your choice. I used AN 6 if I recall correctly. The steel elbows are available form Pegasus racing, Earls and other places I'm sure. The one that I used was a steel AN6 and pipe thread adapter elbow. I cut off the pipe threads and butt welded it to the drilled stock plug. It's not hard to do and not expensive.
MattR |
May 10 2005, 01:09 PM
I read somewhere that the factory used a cooler to spray directly on the gears to keep the gears cool. Maybe I got something mixed up, but wouldnt an arbitrary location kinda defeat the purpose of an oil cooler? I know you're cooling off fluid, but will it really effectivly cool off the gears? And what do you use to pressurize the fluid?
Aaron Cox |
May 10 2005, 01:12 PM
916 boxes had spraybars and an internal pump IIRC and in Iamchappy's pics, you can see his electrical oil pump. |
slivel |
May 10 2005, 01:16 PM
Yes, a spray bar is most effective but understand that the pictures displayed only show the output side of the loop. From the drain plug area the hot oil goes to a pump and cooler then returns to the gearbox. The return can be plumbed to a spray bar over the gearset. In my case, I drilled and tapped one hole over the ring and pinion to dump the cooled oil. Next time I have the gear box apart I might tap 2 or 3 more holes over the gearset for additional cooling. |
MattR |
May 10 2005, 01:21 PM
Got it. Thanks!
Lo-Fi Version | Time is now: 29th April 2024 - 07:45 AM |
