Driving/fog Lights, Relay? |
mmascari |
May 7 2017, 07:29 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
I was trying to get my driving lights/fog lights working and after turning the switch on and testing for voltage at the wires I get nothing. I was reviewing an electrical document and it states that power from the fuse panel goes to a relay. Where is this relay? on the fuse board? If so which one is it?
914Sixer |
May 7 2017, 08:45 PM
Relay is on the fuse panel
oakdalecurtis |
May 7 2017, 08:58 PM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
My suggestion would be to wire your fog lights through an illuminated toggle switch installed in your dash, using a new relay completely independent of your headlight system. That way you can use your foglights whenever you want without having your headlights on and up, or on lowbeams only. With this setup, I use my foglights as Daytime Running Lights whenever I choose to.
mmascari |
May 7 2017, 09:17 PM
914Sixer |
May 8 2017, 01:19 PM
Yes and no. Depends on the year. Turn signal relay may or may not be on fuse panel. Headlight relay is different. All the black round relays are the same. The silver one on 73's that is for the door buzzer
GeorgeRud |
May 9 2017, 08:29 AM
You might occasionally find a red round relay as well. It has some sort of internal wiring difference, though I've long since forgotten what it was.
Lo-Fi Version | Time is now: 17th May 2024 - 10:38 PM |
