Washer Nozzles |
Washer Nozzles |
yeahmag |
May 11 2017, 04:42 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Seems like there is some wild pricing from cheap to expensive on replacement washer nozzles for the 914. Anybody have a recommended replacement?
914Sixer |
May 11 2017, 09:49 PM
914 Guru Group: Members Posts: 8,882 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Autohausaz.com
Chrome with check valve $19.55 70-73 Black plastic $5.27 74-76 Both have adjustable sprayer. |
kgruen2 |
May 25 2017, 02:03 AM
Member Group: Members Posts: 109 Joined: 22-February 15 From: Prescott, Az. Member No.: 18,459 Region Association: Southwest Region |
Autohausaz.com Chrome with check valve $19.55 70-73 Black plastic $5.27 74-76 Both have adjustable sprayer. What do the check valves under the nozzles check? Are they necessary? There appears to have been a change in the nozzles in mid '74. What is the difference in the earlier ones and the new and improved later ones? Are they interchangeable? I switched my pneumatic system to an electric pump system. Would that make a difference? Any thoughts? |
jkb944t |
May 25 2017, 12:00 PM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
Autohausaz.com Chrome with check valve $19.55 70-73 Black plastic $5.27 74-76 Both have adjustable sprayer. What do the check valves under the nozzles check? Are they necessary? There appears to have been a change in the nozzles in mid '74. What is the difference in the earlier ones and the new and improved later ones? Are they interchangeable? I switched my pneumatic system to an electric pump system. Would that make a difference? Any thoughts? I believe that the check valve is to prevent the low pressure area created by the windshield from siphoning out all of the windshield fluid especially at high speeds. Jeff B |
BillC |
May 25 2017, 12:35 PM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
Autohausaz.com Chrome with check valve $19.55 70-73 Black plastic $5.27 74-76 Both have adjustable sprayer. What do the check valves under the nozzles check? Are they necessary? There appears to have been a change in the nozzles in mid '74. What is the difference in the earlier ones and the new and improved later ones? Are they interchangeable? I switched my pneumatic system to an electric pump system. Would that make a difference? Any thoughts? I believe that the check valve is to prevent the low pressure area created by the windshield from siphoning out all of the windshield fluid especially at high speeds. Jeff B Actually, the base of the windshield is a high pressure area. That's why the fresh air intake is there (and why cowl-induction hoods were invented). The check valves are to keep the washer fluid from draining back into the reservoir, which would cause a delay in squirting when the washers are activated. |
Jonathan Livesay |
May 28 2017, 01:18 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Autohausaz.com Chrome with check valve $19.55 70-73 Black plastic $5.27 74-76 Both have adjustable sprayer. What do the check valves under the nozzles check? Are they necessary? There appears to have been a change in the nozzles in mid '74. What is the difference in the earlier ones and the new and improved later ones? Are they interchangeable? I switched my pneumatic system to an electric pump system. Would that make a difference? Any thoughts? I believe that the check valve is to prevent the low pressure area created by the windshield from siphoning out all of the windshield fluid especially at high speeds. Jeff B Actually, the base of the windshield is a high pressure area. That's why the fresh air intake is there (and why cowl-induction hoods were invented). The check valves are to keep the washer fluid from draining back into the reservoir, which would cause a delay in squirting when the washers are activated. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 01:32 PM |
