Lost First Gear, Side Shifter |
motorvated |
May 14 2017, 07:16 AM
Member Group: Members Posts: 280 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
It's my fault. I was on the track and shifting down from fourth to what I thought was third and hit first instead. Now it won't "click" into first and jumps out with grinding. It goes into first but won't stay. All other gears shift fine. Speedometer stopped working about the same time. Not sure if that is related or not. Checked front and rear shift rod bushings and the cup, and they are all Ok. Tried re-adjusting the shifter, but problem remains. Could I have bent the 1st/Reverse shift fork, or moved it on its rod? Reverse works normally, clutch is adjusted properly, and clutch tube is secure. Ideas anyone?
mlindner |
May 14 2017, 11:34 AM
Senior Member Group: Members Posts: 1,522 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
1st gear slider also has the speedo drive gear on it....must have damaged the slider and or gear. Need to take rear cover off transmission to inspect. Do not need to pull transmission. Best, Mark
worn |
May 14 2017, 11:47 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
It's my fault. I was on the track and shifting down from fourth to what I thought was third and hit first instead. Now it won't "click" into first and jumps out with grinding. It goes into first but won't stay. All other gears shift fine. Speedometer stopped working about the same time. Not sure if that is related or not. Checked front and rear shift rod bushings and the cup, and they are all Ok. Tried re-adjusting the shifter, but problem remains. Could I have bent the 1st/Reverse shift fork, or moved it on its rod? Reverse works normally, clutch is adjusted properly, and clutch tube is secure. Ideas anyone? Well, you can readily take off the rear section to expose first and reverse and have a look. When you do get it in gear will first move the car (before it jumps out of gear)? |
flyer86d |
May 14 2017, 01:58 PM
Member Group: Members Posts: 425 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
Had the same thing happen. Engagement dog ring ring teeth were whomped. Removed first gear with trans in the car, rebuilt it and reinstalled.
Charlie |
May 14 2017, 02:14 PM
Pelican has a tech article on doing the replacement: http://www.pelicanparts.com/techarticles/9...anny_repair.htm
--DD |
ThePaintedMan |
May 14 2017, 02:19 PM
Yup, really easy fix. Pull the cover off and inspect the 1st gear dog teeth. Mine were knackered, but I was able to get by for now by filing them and reinstalling it. Temporary fix, and the better solution is to find a new ring, but it'll get you back on the road for the meantime.
motorvated |
May 14 2017, 02:54 PM
Yes, until it pops out of first it tries to move the car. Doesn't sound like too bad of a repair. I guess it's back up on the jack stands again, but hopefully not for long.
Lo-Fi Version | Time is now: 19th May 2024 - 04:38 PM |
