QUOTE(motorvated @ May 14 2017, 05:16 AM)
It's my fault. I was on the track and shifting down from fourth to what I thought was third and hit first instead. Now it won't "click" into first and jumps out with grinding. It goes into first but won't stay. All other gears shift fine. Speedometer stopped working about the same time. Not sure if that is related or not. Checked front and rear shift rod bushings and the cup, and they are all Ok. Tried re-adjusting the shifter, but problem remains. Could I have bent the 1st/Reverse shift fork, or moved it on its rod? Reverse works normally, clutch is adjusted properly, and clutch tube is secure. Ideas anyone?
Well, you can readily take off the rear section to expose first and reverse and have a look. When you do get it in gear will first move the car (before it jumps out of gear)?
