Do all rear fender 6 conversion oil tanks take a 914/6 dipstick? |
john77 |
May 14 2017, 08:01 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Does anyone have a 6 conversion with an oil tank that doesn't take a 9146 dipstick?
I'm not 100% sure which oil tank my car has and a couple of years back I lost my dipstick while at ax. The 9146 dipstick I bought to replace it wouldn't fit so I ended up using a 66-71 911 dipstick instead. Thinking about it, now I just put my engine back in and am trying to figure out how much oil it needs, the only reason I'm using that dipstick is because it fit. For all I know it might not even be the right one. I know the PMS oil tank takes a 9146 dipstick, but what about other aftermarket tanks? Anyone got one that takes a 911 dipstick? |
porschetub |
May 15 2017, 01:31 AM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
You must check what tank you have first ,I haven't been happy with my PMS filler dipstick combo on a stock tank cause I think their fabbed tank is larger...don't really know 100% on that but my tank full I have a low reading.
I do believe that the 914rubber dipstick is correct for stock tank and filler,the 911 dipstick is different because of the filler neck is for that cars tank. More info most likely more answers. |
mb911 |
May 15 2017, 04:58 AM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Unfortunately all the aftermarket tanks mine included are a little larger then stock so they will read different then stock. Thats why its important to put thr 9 qts in start and run engine to operating temp anf mark the dipstick for reference.
GeorgeRud |
May 15 2017, 06:39 AM
Add in a front oil cooler and you really can't tell what the level should be. It might be interesting to see what the actual oil level measures over the engine position to determine what an appropriate level should be to create a safe reservoir to draw from.
May 15 2017, 07:13 AM
914-6 GT in waiting Group: Members Posts: 19,276 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Add in a front oil cooler and you really can't tell what the level should be. It might be interesting to see what the actual oil level measures over the engine position to determine what an appropriate level should be to create a safe reservoir to draw from. I dont think the front cooler changes the oil level reading, just the volume of oil in the system. |
mb911 |
May 15 2017, 07:16 AM
My last conversion car with a vellius (spelling? ) and a front oil cooler took 13 qts.
john77 |
May 15 2017, 09:59 AM
You must check what tank you have first ,I haven't been happy with my PMS filler dipstick combo on a stock tank cause I think their fabbed tank is larger...don't really know 100% on that but my tank full I have a low reading. I do believe that the 914rubber dipstick is correct for stock tank and filler,the 911 dipstick is different because of the filler neck is for that cars tank. More info most likely more answers. The 914/6 dipstick I tried, that didn't fit all the way into the filler neck, was the one from 914rubber. Although, you raise an interesting point, is it possible whoever installed the tank could have used a 911 filler neck and that's why the 911 dipstick fits? My car's at the shop right now so I'll get pictures as soon as I can. I have a front oil cooler set up, which adds to the uncertainty. I can't just put in 9 quarts and start from that point as a reference. |
May 15 2017, 11:52 AM
You must check what tank you have first ,I haven't been happy with my PMS filler dipstick combo on a stock tank cause I think their fabbed tank is larger...don't really know 100% on that but my tank full I have a low reading. I do believe that the 914rubber dipstick is correct for stock tank and filler,the 911 dipstick is different because of the filler neck is for that cars tank. More info most likely more answers. The 914/6 dipstick I tried, that didn't fit all the way into the filler neck, was the one from 914rubber. Although, you raise an interesting point, is it possible whoever installed the tank could have used a 911 filler neck and that's why the 911 dipstick fits? My car's at the shop right now so I'll get pictures as soon as I can. I have a front oil cooler set up, which adds to the uncertainty. I can't just put in 9 quarts and start from that point as a reference. I filled up my oil cooler 1/2 way before I tightened down the lines. I would put in 10 quarts total and start from there. Check the oil as the car warms and add as needed. You won't run it dry if you start off with 10 quarts of oil. |
john77 |
May 15 2017, 02:36 PM
You must check what tank you have first ,I haven't been happy with my PMS filler dipstick combo on a stock tank cause I think their fabbed tank is larger...don't really know 100% on that but my tank full I have a low reading. I do believe that the 914rubber dipstick is correct for stock tank and filler,the 911 dipstick is different because of the filler neck is for that cars tank. More info most likely more answers. The 914/6 dipstick I tried, that didn't fit all the way into the filler neck, was the one from 914rubber. Although, you raise an interesting point, is it possible whoever installed the tank could have used a 911 filler neck and that's why the 911 dipstick fits? My car's at the shop right now so I'll get pictures as soon as I can. I have a front oil cooler set up, which adds to the uncertainty. I can't just put in 9 quarts and start from that point as a reference. I filled up my oil cooler 1/2 way before I tightened down the lines. I would put in 10 quarts total and start from there. Check the oil as the car warms and add as needed. You won't run it dry if you start off with 10 quarts of oil. Thanks mepstein. I've put 10 quarts in so far, on top of whatever oil was left in the front cooler and after warming the engine up it's just showing on the tip of the dipstick (which may or may not be the correct dipstick, so... ). I haven't driven it yet though as, unbelievably, I can't find my damn muffler anywhere in my friends shop - they 'reorganized' a few months back and even though the shop's not that big the damn thing has vanished. Which is worse for the engine, running on the low side or overfilling? |
GeorgeRud |
May 15 2017, 02:55 PM
My conversion -6 with a 2.7 and front Turbotrol cooler takes 10 quarts at an oil change to get the warm idle level to the middle of the dipstick. Once you figure it out, measure how much is drained out at your next oil change.
You must check what tank you have first ,I haven't been happy with my PMS filler dipstick combo on a stock tank cause I think their fabbed tank is larger...don't really know 100% on that but my tank full I have a low reading. I do believe that the 914rubber dipstick is correct for stock tank and filler,the 911 dipstick is different because of the filler neck is for that cars tank. More info most likely more answers. The 914/6 dipstick I tried, that didn't fit all the way into the filler neck, was the one from 914rubber. Although, you raise an interesting point, is it possible whoever installed the tank could have used a 911 filler neck and that's why the 911 dipstick fits? My car's at the shop right now so I'll get pictures as soon as I can. I have a front oil cooler set up, which adds to the uncertainty. I can't just put in 9 quarts and start from that point as a reference. I filled up my oil cooler 1/2 way before I tightened down the lines. I would put in 10 quarts total and start from there. Check the oil as the car warms and add as needed. You won't run it dry if you start off with 10 quarts of oil. Thanks mepstein. I've put 10 quarts in so far, on top of whatever oil was left in the front cooler and after warming the engine up it's just showing on the tip of the dipstick (which may or may not be the correct dipstick, so... ). I haven't driven it yet though as, unbelievably, I can't find my damn muffler anywhere in my friends shop - they 'reorganized' a few months back and even though the shop's not that big the damn thing has vanished. Which is worse for the engine, running on the low side or overfilling? Overfilling. Remember, your oil level will come up as the engine warms up. You always judge a 6 oil level when the engine is hot - not just warm from 5-10 minutes of idle - running and on level ground. |
john77 |
May 15 2017, 08:59 PM
You must check what tank you have first ,I haven't been happy with my PMS filler dipstick combo on a stock tank cause I think their fabbed tank is larger...don't really know 100% on that but my tank full I have a low reading. I do believe that the 914rubber dipstick is correct for stock tank and filler,the 911 dipstick is different because of the filler neck is for that cars tank. More info most likely more answers. The 914/6 dipstick I tried, that didn't fit all the way into the filler neck, was the one from 914rubber. Although, you raise an interesting point, is it possible whoever installed the tank could have used a 911 filler neck and that's why the 911 dipstick fits? My car's at the shop right now so I'll get pictures as soon as I can. I have a front oil cooler set up, which adds to the uncertainty. I can't just put in 9 quarts and start from that point as a reference. I filled up my oil cooler 1/2 way before I tightened down the lines. I would put in 10 quarts total and start from there. Check the oil as the car warms and add as needed. You won't run it dry if you start off with 10 quarts of oil. Thanks mepstein. I've put 10 quarts in so far, on top of whatever oil was left in the front cooler and after warming the engine up it's just showing on the tip of the dipstick (which may or may not be the correct dipstick, so... ). I haven't driven it yet though as, unbelievably, I can't find my damn muffler anywhere in my friends shop - they 'reorganized' a few months back and even though the shop's not that big the damn thing has vanished. Which is worse for the engine, running on the low side or overfilling? Overfilling. Remember, your oil level will come up as the engine warms up. You always judge a 6 oil level when the engine is hot - not just warm from 5-10 minutes of idle - running and on level ground. Ah, good to know. Thanks. |
john77 |
May 15 2017, 09:02 PM
My conversion -6 with a 2.7 and front Turbotrol cooler takes 10 quarts at an oil change to get the warm idle level to the middle of the dipstick. Once you figure it out, measure how much is drained out at your next oil change. Thanks George. My problem isn't so much the oil as the dipstick. If it's not the correct dipstick it's never going to tell me if I have the correct amount of oil. Unless all dipsticks are in a similar ball park, which would seem odd because, well, why have different dipsticks at all? I'm pretty sure I used up my dipstick quota with that reply. |
porschetub |
May 15 2017, 10:34 PM
just don't overfill,our motors don't really like it...ok.
Ok you should be fine ,if your level on the dipstick is middle line,after warming the engine all is good,seems to be a lot of different takes on oil levels appears having a front cooler adds more, no extra thinking required there but how much who can say ? IMO thinking maybe 1 litre but could be more due to cooler and oil line size ? Stock 914/6 is 7 litres but appears many folks run a bit more tends to confuse me but I run a little more due to large oil lines on my 2.2. Really need more "six owners" to chime in eh (IMG:style_emoticons/default/confused24.gif) . |
May 15 2017, 10:39 PM
When he says check it hot, he means hot.
My 911 shows nothing or just on the tip when cold. Hot is a big difference in volume. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:50 PM |
