Sold:1972 Porsche 914 1.7L L-jet $2250 with title |
kenboytay123 |
May 15 2017, 11:40 AM
Newbie Group: Members Posts: 11 Joined: 24-September 15 From: Corinth, Ky Member No.: 19,197 Region Association: None |
FS: 1972 Porsche 914 1.7L L-Jet $2250 with title!!!
This is a great looking car (pictures to be posted tonight) I got from Brad Mayor in Indiana in 2015 I believe. My plan was to restore it, but due to recent plans to move to a smaller house I need to get rid of it. I don't have a lot of wiggle room in the price but I could drop a little if you pick it up soon!!! I originally got it without the following: Wheels and Tires, Fuel Pump, Bumpers, Rocker Trim piece, Door handles, Compression on all 4 cylinders brakes Intake & Injection system Battery other small bits and pieces I added: Everything above except brakes. I've gathered rebuild kits for the calipers I was going to use, but I don't have time for it before we move. Old Compression: #1: 150lbs #2: 114lbs #3: 156lbs #4: 130lbs After valve adjustment on 2 & 4 #1: 150lbs #2: 145lbs #3: 156lbs #4: 140lbs Not perfect but way better than 114lbs. Valve was too tight. Electrically speaking the car seems to be in good shape lights work and engine cranks & runs minus 1 small flaw. Small flaw: There's no hole for my head temp sensor for the 1.8L L-jet. I'm not sure if 1.7L didn't have this hole or not, but I guess I overlooked that detail before I put in the fuel injection. The car will run when the sensor is grounded but I wouldn't recommend driving it until the sensor is installed correctly. There has been some welding done on the car before I got it, but it looks to be in good shape and could easily be brought up to a road worthy car. I need this gone soon, Cash only! Title in hand. Thanks |
kenboytay123 |
May 24 2017, 04:52 AM
After further investigation, I found that yes the heads are on backwards.... (IMG:style_emoticons/default/headbang.gif)
You can see the cht sensor hole in the driver side just behind the #2 cylinder sparkplug. (through the sparkplug hole in the tin.) |
Lo-Fi Version | Time is now: 11th May 2024 - 05:03 AM |
