FS: 1972 Porsche 914 1.7L L-Jet $2250 with title!!!
This is a great looking car (pictures to be posted tonight) I got from Brad Mayor in Indiana in 2015 I believe. My plan was to restore it, but due to recent plans to move to a smaller house I need to get rid of it. I don't have a lot of wiggle room in the price but I could drop a little if you pick it up soon!!!
I originally got it without the following:
Wheels and Tires,
Fuel Pump,
Bumpers,
Rocker Trim piece,
Door handles,
Compression on all 4 cylinders
brakes
Intake & Injection system
Battery
other small bits and pieces
I added:
Everything above except brakes.
I've gathered rebuild kits for the calipers I was going to use, but I don't have time for it before we move.
Old Compression:
#1: 150lbs
#2: 114lbs
#3: 156lbs
#4: 130lbs
After valve adjustment on 2 & 4
#1: 150lbs
#2: 145lbs
#3: 156lbs
#4: 140lbs
Not perfect but way better than 114lbs. Valve was too tight.
Electrically speaking the car seems to be in good shape lights work and engine cranks & runs minus 1 small flaw.
Small flaw:
There's no hole for my head temp sensor for the 1.8L L-jet. I'm not sure if 1.7L didn't have this hole or not, but I guess I overlooked that detail before I put in the fuel injection. The car will run when the sensor is grounded but I wouldn't recommend driving it until the sensor is installed correctly.
There has been some welding done on the car before I got it, but it looks to be in good shape and could easily be brought up to a road worthy car.
I need this gone soon, Cash only! Title in hand.
Thanks
