WTB: bottom engine tin pieces 1.7l, Need the flat pieces under the cylinders |
theer |
May 15 2017, 08:32 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Looking for the flat engine tin pieces covering the bottom of the cylinders, and thermostat, for 1.7l. These are the pieces that connect to the bottom of the engine block on the inside and the HE on the outside.
Mine are bent to hell. Need both sides. Looking for decent & straight. This is not a show car. Thanks, Tom |
bdstone914 |
May 15 2017, 11:18 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Looking for the flat engine tin pieces covering the bottom of the cylinders, and thermostat, for 1.7l. These are the pieces that connect to the bottom of the engine block on the inside and the HE on the outside. Mine are bent to hell. Need both sides. Looking for decent & straight. This is not a show car. Thanks, Tom Sounds like you are referring to the warm air guides. What year is the car? The passenger side is the same for all years but the drivers is different or tail shift or side shift transmission cars. |
theer |
May 16 2017, 06:55 AM
Thanks for clarifying - I was not aware of the differences.
Ah well, the year of the car is an interesting question... The car is a '72, but the motor is the 1.7l from a '70... but I have the later side-shifts trans. So, I guess that means I need the later tin piece for the driver side. |
May 16 2017, 09:33 AM
Thanks for clarifying - I was not aware of the differences. Ah well, the year of the car is an interesting question... The car is a '72, but the motor is the 1.7l from a '70... but I have the later side-shifts trans. So, I guess that means I need the later tin piece for the driver side. Correct |
theer |
May 16 2017, 05:19 PM
Bump. Anyone?
KevinW |
May 16 2017, 08:19 PM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
Attached thumbnail(s) |
theer |
May 17 2017, 05:25 AM
Exactly. Thanks Kevin. That's the driver side, need the passenger side as well
bdstone914 |
May 17 2017, 07:35 AM
theer |
May 17 2017, 08:32 AM
Wait, what?
I have the side-shift transmission on an early car, so I do need the late engine tin... right? |
theer |
May 17 2017, 08:35 AM
.. and still looking for a passenger side piece...
bdstone914 |
May 17 2017, 10:13 AM
914werke |
May 17 2017, 11:04 AM
"I got blisters on me fingers" Group: Members Posts: 10,004 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Wait, what? I have the side-shift transmission on an early car, so I do need the late engine tin... right? That part is 76-76 onlyI think Bruce meant 75-76 only. The part pictured is one of the warm air guides for a LATE HE system found on all 75-76 cars. You are looking for the same type of part but for any Side shift equipped car prior to 75 |
theer |
May 17 2017, 01:14 PM
OK, Thanks everyone for the input. Who knew... there arre three different pieces for that one area. Oh well.
I found this on fleabay, which I think is the correct driver's side piece I will need: http://www.ebay.com/itm/ENGINE-TIN-Btm-COV...2z3&vxp=mtr It's missing one of the attachment tabs, so quite pricey at $38, IMHO. AA has them, too, but almost twice that. Sheesh. I put my shitty early one on and it "fits", although the shift linkage rod is really tight in the channel. Might just go with that for now. |
Lo-Fi Version | Time is now: 25th April 2024 - 10:33 PM |
