Momo hub install...., horn goes off continuously |
BuddyV |
May 16 2017, 11:34 AM
Robert Group: Members Posts: 555 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
So..... went to install a Momo hub on my 1975 914. Goes on securely...... but the horn blows as soon as I turn on the ignition.
Is there a spacer that I should install? Or ???? ??? |
oakdalecurtis |
May 16 2017, 12:12 PM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Hi Buddy,
I put in a Momo years ago. Figure out which wire to the horn button is the hot lead, I think it's the black with yellow stripe wire. This lead is grounding out on the hub at some point which makes the horn go on. I remember having to dremel away some of the aluminum inside the hub to allow this hot lead wire to clear and not ground out. Once you do that, the horn should work fine. Also, if your Momo wheel is a smaller diameter than the stock wheel, check out the JWest eccentric spacer at this website: http://www.jwesteng.com/shop/home/15-steer...ic-adapter.html I highly recommend it. This spacer will move the wheel about a half inch closer to you, but more importantly, it will raise the smaller wheel about an inch. This will allow you to see your gauges properly and also increase leg room under the wheel even more. Here's pics of before and after spacer installation: |
theleschyouknow |
May 16 2017, 06:42 PM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
Hi Buddy, I put in a Momo years ago. Figure out which wire to the horn button is the hot lead, I think it's the black with yellow stripe wire. This lead is grounding out on the hub at some point which makes the horn go on. I remember having to dremel away some of the aluminum inside the hub to allow this hot lead wire to clear and not ground out. Once you do that, the horn should work fine. Also, if your Momo wheel is a smaller diameter than the stock wheel, check out the JWest eccentric spacer at this website: http://www.jwesteng.com/shop/home/15-steer...ic-adapter.html I highly recommend it. This spacer will move the wheel about a half inch closer to you, but more importantly, it will raise the smaller wheel about an inch. This will allow you to see your gauges properly and also increase leg room under the wheel even more. Here's pics of before and after spacer installation: what's that toggle switch on the dash left of the column? (IMG:style_emoticons/default/beerchug.gif) cjl |
oakdalecurtis |
May 16 2017, 08:55 PM
The toggle switch is for my fog lights. I rewired the fog lights to be switched independently of the headlight switch. That way I can use the fog lights as Daytime Running Lights without having to raise my headlights, and the fog lights are now independent of the headlight's high/low beam selection too. I converted the toggle switch to an amber illuminated toggle when I did the rewire so I would know when the fog lights were on.
porschetub |
May 18 2017, 02:58 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Are you using a Momo horn button,all the ones I've had have 2 wires ,ones right and ones wrong.
You may find even if you have the right wire connected it could be touching somewhere inside the hub,things are rather tight in there. Didn't think the stock horn ring was a very good fit,shame on Momo (IMG:style_emoticons/default/mad.gif) . |
Lo-Fi Version | Time is now: 19th May 2024 - 11:54 PM |
