shifter bushing, trick for installation |
joeav8tor |
May 10 2005, 05:53 PM
Member Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 |
I am in the garage right now and the main shifter bushing (the one that is in the firewall) is kicking my ass.
I heated up some water and soaked it to soften it up, but the shit is not going in there...I have tried using two screwdrivers.... and a deep well socket and light ly tapping it...any help would be appreciated greatly. (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/flag.gif) Joe |
BIGKAT_83 |
May 10 2005, 05:56 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
You do have the main shift rod out? If not take it out and bushing taps right in.
Bob |
chilli |
May 10 2005, 05:57 PM
Older Than Dirt :-) Group: Members Posts: 220 Joined: 24-March 05 From: Sacramento, CA Member No.: 3,805 |
(IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) It has been awhile since I did mine, but from old memory, I remember that it was real pain is the butt. I do remember that to use a very good silicone like lubricant, started one side of it then 'hammered" it in.
Hope this helps, mike (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
Red-Beard |
May 10 2005, 06:05 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
I pounded the last one in and that worked fine. On my 1971, since I installed it with the rod in place, I cut the bushing in 1/2 and installed the top, then the bottom. Worked great.
d7n7master |
May 10 2005, 06:21 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
...add a wooden block. Place the firewall bushing in the hole. Square it up. Grab the wooden block Place it against the bushing. Hold in place with all of your fingers & thumbz away from where you are about to HIT with BFH. (Big f hammer). Your done. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Allan |
May 10 2005, 06:49 PM
I didn't really have a problem putting mine in. Tried the block and hammer method and that didn't work. Just warmed it up real good and pushed it in. I had to heat it until it was soft enough to deform.
phantom914 |
May 10 2005, 10:17 PM
non-914-owner non-club member Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 |
I used a large socket on the inside of the car, large enough to fit around the lip around the hole. I passed a long carriage bolt through the socket, the hole in the firewall and through the bushing, put a fender washer and then a nut on (the washer and nut are on the engine side of the fire wall) and tightened the nut to press the bushing in.
Andrew |
Joseph Mills |
May 10 2005, 10:25 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
I think all of these suggestions should go in a thread entitled "Tips and procedures not found in the Haynes manual." Or something like that.
The following was suggested by a long time porsche mechanic. I tried it and it worked great. Make a sharp diagonal cut thru the bushing. Stick the sharp end in the hole and just twist it in. If it resists at all, a light tap will inch it in. took about one minute to install. Now the shifter boot that covers that mess is a bit tougher. Getting the boot seated all the way around that narrow ass lip is a pain. My friend Craig (Cametal) showed me a good trick he discovered. Hook the top side over the lip. Then insert your finger inside from the other end of the boot (towards the tranny) and locate the rim of the boot from inside and push it over the retaining lip a bit at a time. Combine a handful of profanity and a few minutes of your time and it's done. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) The other end of the boot slips in place very easily. In fact, I did this one just a few hours ago after installing my new clutch. |
Lo-Fi Version | Time is now: 29th April 2024 - 07:40 AM |
