25Amp Battery Fuse Melted |
bandjoey |
May 19 2017, 08:06 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
About a year ago a member here sold a battery fuse kit (Spoke?) Never thought I'd use it but it looked cool.
Started the teener tonight and after a minuted it went Dead Instantly! Knew it was electrical and since I'd recently installed a tach, decided to check the wires. Looked OK. and the dash fused were ok too. Checked the battery fused and found a blown 25 amp fuse. When I think of what might have melted without that fuse................... (IMG:style_emoticons/default/headbang.gif) As soon as the butterfly horn was off, I see a cut horn wire. The DAPO installed this and I have been to lazy to wire it right. Pulled off the horn wire, installed a new fuse, and took her for a spin! With Tim's new LED dash lights, I love driving after dark. So,,,fuse the battery and let Tim do your dash. Attached image(s) |
stinkindiesel |
May 22 2017, 01:07 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
I learned this lesson on a very early build 944. Turned the headlights on one night. One popped up, the other didn't. Smoke poured out from under the dash. Entire wiring harness going through the firewall was one big lump of goo. Found out later the headlight motors were unfused. All it took was a stalled motor to lead to a short to lead to China Syndrome.
Gary |
Lo-Fi Version | Time is now: 22nd May 2024 - 01:01 AM |
