914/6 Flywheel |
914/6 Flywheel |
paintracer1 |
May 20 2017, 11:05 AM
Newbie Group: Members Posts: 11 Joined: 2-January 12 From: Maryland Member No.: 13,957 Region Association: MidAtlantic Region |
I bought the Kennedy conversion flywheel to use a 901-914 trans on my 2.7/6 cylinder engine. When i bolted it up to my engine i could not turn the engine over. The flywheel is rubbing the the case halves where the two bottom case bolts are-( I'll call it the webbing of the case. Has anyone eles had this problem? or yes its a very tight clearence between the flywheel and case. I filed the case down a little- made it flat instead of being curved seems to be working with out taking to much material off. Any insight into this would be appreciated. Thanks
Lo-Fi Version | Time is now: 18th May 2024 - 02:08 PM |
