distributor & carbs |
JFG |
May 20 2017, 03:42 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
My stock 1.7 w code motor is being built and will run twin 40 webers. The engine came with a distributor with the following part number 022 905 205 H and part of the fuel injection on it.
It has a vac advance and appears to be in excellent condition inside. Will the above carb / dizzy combo work? If not what set up have people found to work best based on my set up? |
larryM |
May 20 2017, 11:10 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
it will work, but maybe not "best" for your setup
- the more important item is what cam you are using in your build ?? the D-jet cam is no good for your webers if you have different more aggressive cam, you'll want to have your distributor curved to match it's characteristics whatever you do - DO NOT get a "009" distributor an "034 SVDA" would be a better option - just go to eBay & search for "034 svda" and - google it - you'll find lots of folks on The Samba who know a lot about what you want to do |
JFG |
May 21 2017, 01:31 AM
Thanks for the advice. Had problems with 009's in the past so will steer clear of them.
I didn't want to have to split the case but if i must so be it. If i do replace the cam (assuming next size up from standard) do i need to replace lifters & rods? Ideally i want to keep the engine as stock 1700 as possible without pumping it up in combustion size. Any suggestions from people who have built and run this? If the idf's require too much work is there a twin set up alternative. I've been on the samba but i seem to find power builds. |
Keith914 |
May 21 2017, 08:18 AM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
Thanks for the advice. Had problems with 009's in the past so will steer clear of them. I didn't want to have to split the case but if i must so be it. If i do replace the cam (assuming next size up from standard) do i need to replace lifters & rods? Ideally i want to keep the engine as stock 1700 as possible without pumping it up in combustion size. Any suggestions from people who have built and run this? If the idf's require too much work is there a twin set up alternative. I've been on the samba but i seem to find power builds. Carbs need a vacuum advance in order to have a smooth low rpm idle (800) with correct timing at higher rpm's (+2500) |
larryM |
May 22 2017, 10:37 AM
yes - replace the cam & lifters as a set, pushrods are not an issue,
you want a cam that is designed for carbs - google this for several good links "camshaft for type 4 with carbs" and be wary of bolt-on replacement cam gears since they can "come loose" and make a terrible knocking sound - be sure you properly secure the bolts & use loctite split the case: most of us old-timers have btdt on these matters - hard knocks of experience when we had no internet to ask answeres of Thanks for the advice. Had problems with 009's in the past so will steer clear of them. I didn't want to have to split the case but if i must so be it. If i do replace the cam (assuming next size up from standard) do i need to replace lifters & rods? |
Mark Henry |
May 22 2017, 11:25 AM
I'd build it with a better cam, mild carb cam for a small displacement engine. A Web 86 or scat C-25 are mild carb cams without the huge lifts of bigger cams.
If too late for a cam change I'd bite the bullet and do a stock 1.7, or 1.8 L-jet or MS EFI system. For the MS I'd mod the runners a 2.0 plenum TB and air cleaner assembly. Weber's I'd use a mallory red cap dizzy, new or you can buy used and mod the points to the unilight or a pertronix ignitor. 2nd choice for cheap I'd use a L-jet bus or 914 dizzy and block off the vac advance. 3rd choice(s) would be something like the 123 dizzy or a megajolt jr ignition. |
BK911 |
May 22 2017, 02:52 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Wow, I hope my car doesn't read some of the advice here.
I run a stock cam in my 1.7 with dual EMPIs. I also have a 009. Car runs awesome!! |
72hardtop |
Nov 2 2018, 08:37 PM
Member Group: Members Posts: 120 Joined: 11-September 13 From: Seattle/HB Ca./Fujieda-Japan Member No.: 16,378 Region Association: Pacific Northwest |
Wow, I hope my car doesn't read some of the advice here. I run a stock cam in my 1.7 with dual EMPIs. I also have a 009. Car runs awesome!! And I'll bet it's overly rich most of the time. With a 009 one always has to jet it rich to get rid of the off idle stumble. Drop an SVDA in it and drop your idle jets (1) size minimum and the engine will wake up literally. |
Lo-Fi Version | Time is now: 29th April 2024 - 07:30 AM |
