distributor & carbs |
JFG |
May 20 2017, 03:42 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
My stock 1.7 w code motor is being built and will run twin 40 webers. The engine came with a distributor with the following part number 022 905 205 H and part of the fuel injection on it.
It has a vac advance and appears to be in excellent condition inside. Will the above carb / dizzy combo work? If not what set up have people found to work best based on my set up? |
larryM |
May 20 2017, 11:10 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
it will work, but maybe not "best" for your setup
- the more important item is what cam you are using in your build ?? the D-jet cam is no good for your webers if you have different more aggressive cam, you'll want to have your distributor curved to match it's characteristics whatever you do - DO NOT get a "009" distributor an "034 SVDA" would be a better option - just go to eBay & search for "034 svda" and - google it - you'll find lots of folks on The Samba who know a lot about what you want to do |
Lo-Fi Version | Time is now: 14th May 2024 - 06:53 PM |
