distributor & carbs |
JFG |
May 20 2017, 03:42 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
My stock 1.7 w code motor is being built and will run twin 40 webers. The engine came with a distributor with the following part number 022 905 205 H and part of the fuel injection on it.
It has a vac advance and appears to be in excellent condition inside. Will the above carb / dizzy combo work? If not what set up have people found to work best based on my set up? |
BK911 |
May 22 2017, 02:52 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Wow, I hope my car doesn't read some of the advice here.
I run a stock cam in my 1.7 with dual EMPIs. I also have a 009. Car runs awesome!! |
72hardtop |
Nov 2 2018, 08:37 PM
Member Group: Members Posts: 120 Joined: 11-September 13 From: Seattle/HB Ca./Fujieda-Japan Member No.: 16,378 Region Association: Pacific Northwest |
Wow, I hope my car doesn't read some of the advice here. I run a stock cam in my 1.7 with dual EMPIs. I also have a 009. Car runs awesome!! And I'll bet it's overly rich most of the time. With a 009 one always has to jet it rich to get rid of the off idle stumble. Drop an SVDA in it and drop your idle jets (1) size minimum and the engine will wake up literally. |
Lo-Fi Version | Time is now: 15th May 2024 - 07:35 PM |
