plastic fuse panel cover, how to keep it attached? |
iankarr |
May 20 2017, 04:16 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Hi Guys,
Maybe a silly question, but is there a trick for getting it to stay on? The nubs are there on the plastic cover, but it doesn't seem to want to wedge into place on the fuse panel. Thanks! |
914_teener |
May 20 2017, 04:18 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Have your legs shortened?
I haven't found a way to keep my knee from hitting it once and awhile and still keep it on. Sorry. |
porschetub |
May 20 2017, 04:20 PM
Have your legs shortened? I haven't found a way to keep my knee from hitting it once and awhile and still keep it on. Sorry. Yea they just fall of if bumped even lightly,mine lives in the glovebox (IMG:style_emoticons/default/lol-2.gif) |
oakdalecurtis |
May 20 2017, 04:23 PM
Oakdalecurtis Group: Members Posts: 1,323 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
I put a male n female velcro strip attached to the top side of the relay board that come below and over the cover. No more bumping it off!
Rand |
May 20 2017, 05:47 PM
The replacement options with modern blade fuses are sure a nice upgrade. For example:
https://www.jwesteng.com/shop/electrical-91...-fuse-box-.html No more knocking the cover loose, or worse yet a bunch of fuses too. |
michael7810 |
May 20 2017, 05:48 PM
Senior Member Group: Members Posts: 1,079 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
JWest Engineering has a solution::
iankarr |
May 20 2017, 08:39 PM
Well, nice to know it's not just me...
The Jwest panel may be on the list for next winter's upgrades. For now, I guess my fuse cover will stay in the glovebox. |
TheCabinetmaker |
May 20 2017, 09:09 PM
Leave the cover on. Without it, you will knock out a few fuses with your knee or foot. When you do, it will be late at night, after a drink. The fuse you kick out will be the ones that control the interior and exterior lights, or(heaven forbid) the one that keeps the car from starting. You will be on your knees fumbling to put the fuse back in, but you can't see. All the while, you'll be thinking: Where's my frigging fuse box cover?!
Coondog |
May 20 2017, 09:37 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
green914 |
May 20 2017, 09:42 PM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
Well, nice to know it's not just me... The Jwest panel may be on the list for next winter's upgrades. For now, I guess my fuse cover will stay in the glovebox. I think I will being doing the same upgrade this winter. (IMG:style_emoticons/default/agree.gif) |
Rand |
May 20 2017, 09:55 PM
Leave the cover on. Without it, you will knock out a few fuses with your knee or foot. (IMG:style_emoticons/default/agree.gif) If you've ever knocked the cover loose, imagine what would happen with the cover off. Fuses bouncing all over the floor like dumping a box of chicklets. BTDT. I'd tape it on if I had to until the Jwest unit arrived. |
rgalla9146 |
May 21 2017, 06:06 AM
Ian are you sure that the cover isn't cracked ?
Garland |
May 21 2017, 09:33 AM
Restoration Fanatic Group: Members Posts: 1,327 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
It only goes on one way, flip it over. It should stay in place. (IMG:style_emoticons/default/blink.gif)
frankiec@outrageous.net |
May 21 2017, 10:12 AM
Member Group: Members Posts: 81 Joined: 31-March 13 From: Mendocino, CA Member No.: 15,717 Region Association: Northern California |
Well, I had the same problem with a cracked cover. Ordered a replacement and in the correct position it still dropped off. I turned the cover around and it went right into place and have had no problems since. (IMG:style_emoticons/default/idea.gif)
It only goes on one way, flip it over. It should stay in place. (IMG:style_emoticons/default/blink.gif) |
iankarr |
May 21 2017, 04:27 PM
Ian are you sure that the cover isn't cracked ? It wasn't when I was trying to get it to stay (for about 15 minutes). Both ways. Then I cracked it when I pinched too hard. (IMG:style_emoticons/default/headbang.gif) Oh well...I'll try the velcro thing. But I never really had a problem without a cover anyway. |
oakdalecurtis |
May 21 2017, 07:50 PM
PlaysWithCars |
May 21 2017, 11:53 PM
Senior Member Group: Members Posts: 523 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
I need to get me a fuse cover. I keep knocking fuses out with my knee. In my old car at least when I hit the fuse cover, if I did knock any fuses out, there was a convenient diagram telling where the important ones went back to.
Fuses bouncing all over the floor like dumping a box of chicklets. |
JawjaPorsche |
May 22 2017, 03:00 PM
A new fuse cover solved my problem. Also careful getting in helps too.
erwindv |
May 23 2017, 06:31 AM
Newbie Group: Members Posts: 46 Joined: 17-June 16 From: Belgium Member No.: 20,119 Region Association: Europe |
76-914 |
May 23 2017, 08:17 AM
I made some of these a few years back. I haven't knocked one of these out yet! (IMG:style_emoticons/default/beerchug.gif) http://www.914world.com/bbs2/index.php?sho...=114442&hl=
Lo-Fi Version | Time is now: 26th April 2024 - 08:12 AM |
