Brand New Weber 44 Leaking! |
MikeM |
May 20 2017, 08:17 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...
Last fall I bought and installed new made in Spain Weber 44's. I have driven maybe 50 miles since installation. Today after I drive I smelled and noticed a fuel leak. Fuel was dripping off the accelerator pump adjustment rod under the diaphram housing. It was not coming from the housing itself but from under it, in the middle of the 2 barrels . It was a pretty good drip that started several minutes after shutting off the engine. It does not appear to leak with the engine running. All I've done recently is installed larger idle jets and installed the rotary fuel pump from CB Performance. Any and all help and advice appreciated. Thanks. Mike |
MikeM |
May 21 2017, 08:51 PM
Well...we took the carb off and checked the float setting. It all looked good.
Cleaned the jets for good measure and put the carb back on the car. Same problem. I drive the car and get it warmed up. After it's shut down for about 15 minutes it starts to leak. Looking down into the throats of the carb we can see gas dripping onto the butterfly. So, is this too much pressure in the float bowl or is it engine heat boiling the gas out the top of the float bowl?? Again, it's a NEW CB Performance fuel pump internally regulated to 3.5 lbs. Also it only happens on one side of the engine. All tips appreciated. Mike |
Lo-Fi Version | Time is now: 19th May 2024 - 12:13 AM |
