Horn Problem, Horn doesn't work |
capitolatim |
May 21 2017, 05:53 PM
Member Group: Members Posts: 64 Joined: 11-June 15 From: capitola,ca Member No.: 18,841 Region Association: Northern California |
r_towle |
May 21 2017, 09:50 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I believe its a grounding issue behind he wheel.
Take it off and take a look at the contact that the red wire is using on the metal ring on the back side of that wheel hub. That is how it gets its ground, so it needs to be a great connection, and super clean. its two rings, one wire from below (brown/white) to the lower ring, and your red lead is connected to the upper ring. rich |
porschetub |
May 21 2017, 10:49 PM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I believe its a grounding issue behind he wheel. Take it off and take a look at the contact that the red wire is using on the metal ring on the back side of that wheel hub. That is how it gets its ground, so it needs to be a great connection, and super clean. its two rings, one wire from below (brown/white) to the lower ring, and your red lead is connected to the upper ring. rich (IMG:style_emoticons/default/agree.gif) appears to be a short there,maybe the contact ring isn't right,but we don't know if its a stock one or Lecarra one depends on the boss used of course. Just fitted momo adaptor and other aftermarket wheel,touch the horn wire to the wheel and all is load and clear. |
Lo-Fi Version | Time is now: 25th May 2024 - 10:08 AM |
