Window adjustments, Seals not aligning with the window |
North Coast Jim |
May 22 2017, 02:55 PM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
The project Scarecrow is coming down to the finish line. Being a Scarecrow we've had to source many parts that were not on the car as sold originally. The Barn Find having been picked clean as a parts donor over the years. Couldn't pass up a 25 year old rust free shell, a 74 2L, and the rest is history. There was No rust on this shell and all the original seam sealer is intact. Original battery tray too. Hell hole is a sight to admire nothing but dust here. I see no evidence of any sheet metal work having been done. Car is straight in all respects.
Car is running but one of the last items to complete is to add the seals around both roll up windows inclusive of the seal at the top as part of the removable targa top. I've been at this for over a week now and no amount of reading posts on World, reviewing the Haynes manual or other sources of information has gotten me any closer to a solution. I provide a few pics. The B pillar seems to be too forward at the base and not tall enough at the top. I can see light at the rubber cap fitting at the top. Tried to capture it one of the pics. With the window rolled up all the way there is a gap to the targa top seal of about 1/4". It doesn't even come close. No amount of adjustment gets me any closer. I'm using 914 Rubber seals exclusively. I've read where are there are a couple different targa top types. Are there differences in the top at to the top of the door window ?? Has the track that hold the seal ever been shimmed moving it down toward the top of the window. What about the B pillar ?? Are there different lengths and mounting styles ?? Top of door gap is larger then elsewhere. Don't think plays in the problem and again no amount of adjustment gets this gap minimized. Any other suggestions for me. This is frustrating. By the way I hope to have this car at the Stoddard's swap meet June 4th. 100 mile drive an a fresh rebuild. Hope it doesn't rain. |
North Coast Jim |
May 24 2017, 11:29 AM
So a review using Sir Andys posted pictorial description
http://www.914world.com/bbs2/index.php?showtopic=73129 shows that I have an early top on a late car. Worse yet also have an early rubber "bumper" on the pass side and a late on the other. Also and this didn't show up in the early/late Targa top post but there seems to also be different receivers/catches that are mounted on the roll bar top. I measured about .150" difference in the two (.300"-.150"). This is measuring just the depth to the two sides of the catch. Seems this hoghe podge of parts are not compatible. Also it shows that the top is too high especially in the pass side where the early rubber bumper is, therefore not meeting the window producing gaps and not making the seal. It still seems probable that the later tops "step" as called out in the post also helps to produce the gap and hence no seal. Now if only I knew the "step" height I could make a spacer under the channel for the top window seal. Hmmm. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:54 PM |
