Engine first start attempt., Couple vacuum leaks, Finally adustable idle. |
Olympic 914 |
May 23 2017, 07:30 AM
Group: Members Posts: 1,668 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Engine first start, Fail.
Yesterday I made the first attempt at starting the engine since rebuild. I had put two gallons of 93 octane gas into the tank and the pump runs as it should when turning the key. I had a timer ready to perform the 20 minute cam break in. I was arrogant enough to believe that the engine would simply start when I finally tried it. WRONG. It caught for a few moments then died. And subsequent attempts gave no better of a response. I had turned the engine over with the coil disconnected to build up oil pressure before attempting the start. And thought I may have run the battery down some. Checking it showed 12.56v resting and 11.44 while cranking. I connected a big boat battery with jumper cables but still no start. It turns over and fires a couple times giving of puffs of exhaust, but does not catch and keep running. Pulled a FI hose and checked that I am getting gas, also pulled two plugs and they are wet with gas. I thought I may have flooded it so I put the battery charger on it and put it back in the garage. This morning I tried it again and the result was the same. It fires a couple times then just cranks. Everything is new. Cap and rotor, points condenser plug wires etc. injectors rebuilt buy Witchhunters , static timed when I put in the distributor. All new vacuum hoses, rebuilt MPS (set to 037 specs) ECU is an unknown but it worked when ran last (in ’89) all the wiring was carefully checked when installed Engine build is as follows. EA 1.7 engine built into a 2056 Using the djet FI with 2.0 parts, intake runners, throttle body, air cleaner, etc. HAM heads ported to RS+ and modified for the 2.0 runners Raby 9590 cam Guess I will start with rechecking the timing and go from there. |
Olympic 914 |
May 23 2017, 12:20 PM
Now its starts right up but the rpms go to 3000+ and the idle speed screw on the throttle body is IN as far as it will go. the throttle cable has play in it, so that is not causing it. checked the hoses for a vacuum leak but can't find anything that is off right now.
So now I have another issue to look for. (Edited) |
BeatNavy |
May 23 2017, 12:40 PM
Now its starts right up but the rpms go to 3000+ and the idle speed screw on the throttle body is out as far as it will go. the throttle cable has play in it, so that is not causing it. checked the hoses for a vacuum leak but can't find anything that is off right now. So now I have another issue to look for. Do you mean the idle air bypass screw is all the way IN? Out is going to increase idle speed (like a vacuum leak). Put that back in part way (for the time being), check timing again (it could be too far advanced), and thoroughly check for vacuum leaks, particularly a disconnected hose. If your timing is close and the idle air bypass is not all or mostly open and you still can't get below 3,000, then it's a substantial leak (like a big ol' hose unplugged) or the throttle body not seated on manifold. But congrats on getting it running (IMG:style_emoticons/default/smile.gif) You'll find the issue. |
Lo-Fi Version | Time is now: 16th May 2024 - 07:11 PM |
