Engine first start attempt., Couple vacuum leaks, Finally adustable idle. |
Olympic 914 |
May 23 2017, 07:30 AM
Group: Members Posts: 1,668 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Engine first start, Fail.
Yesterday I made the first attempt at starting the engine since rebuild. I had put two gallons of 93 octane gas into the tank and the pump runs as it should when turning the key. I had a timer ready to perform the 20 minute cam break in. I was arrogant enough to believe that the engine would simply start when I finally tried it. WRONG. It caught for a few moments then died. And subsequent attempts gave no better of a response. I had turned the engine over with the coil disconnected to build up oil pressure before attempting the start. And thought I may have run the battery down some. Checking it showed 12.56v resting and 11.44 while cranking. I connected a big boat battery with jumper cables but still no start. It turns over and fires a couple times giving of puffs of exhaust, but does not catch and keep running. Pulled a FI hose and checked that I am getting gas, also pulled two plugs and they are wet with gas. I thought I may have flooded it so I put the battery charger on it and put it back in the garage. This morning I tried it again and the result was the same. It fires a couple times then just cranks. Everything is new. Cap and rotor, points condenser plug wires etc. injectors rebuilt buy Witchhunters , static timed when I put in the distributor. All new vacuum hoses, rebuilt MPS (set to 037 specs) ECU is an unknown but it worked when ran last (in ’89) all the wiring was carefully checked when installed Engine build is as follows. EA 1.7 engine built into a 2056 Using the djet FI with 2.0 parts, intake runners, throttle body, air cleaner, etc. HAM heads ported to RS+ and modified for the 2.0 runners Raby 9590 cam Guess I will start with rechecking the timing and go from there. |
r_towle |
May 23 2017, 07:08 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Remove all the vacuum lines except the mps.
Cover all the plenum holes with electrical tape. Check and verify the distributor advance plates move freely with no binding from full retard to full advance. Sometimes the point screw is too long for that spot and you may have used the short one for the cover clips or advance plates. (Sorry, pull it out again) It's either air or timing. Sounds like air. |
Olympic 914 |
May 24 2017, 06:23 AM
Remove all the vacuum lines except the mps. Cover all the plenum holes with electrical tape. Check and verify the distributor advance plates move freely with no binding from full retard to full advance. Sometimes the point screw is too long for that spot and you may have used the short one for the cover clips or advance plates. (Sorry, pull it out again) It's either air or timing. Sounds like air. I will try this next, and check the distributor parts too. Thanks Put new injector seals in, and had injectors refurbished by Witchhunters. But maybe the seals are not sealing correctly. And I sanded and painted the plenum myself, So should not be any holes rusted through. These are all good suggestions and some I have thought of. I can't rule out any possibility until I solve this dilemma. One thing I haven't checked and will look at today is if somehow the throttle plate is being sucked open some when its running. maybe the spring is not on correctly. (Just checked and spring is holding throttle plate tight, So one thing down) It does not seem reasonable that it could run at 3000+ rpm with the throttle plate closed. |
ChrisFoley |
May 26 2017, 09:49 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
And I sanded and painted the plenum myself, So should not be any holes rusted through. The problem with 2L plenums isn't rust holes. Stress cracks can form on the underside, especially around one of the tubular reinforcements. Such stress cracks may be nearly invisible even after sanding, and only open up under high manifold vacuum. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:14 AM |
