Engine first start attempt., Couple vacuum leaks, Finally adustable idle. |
Olympic 914 |
May 23 2017, 07:30 AM
Group: Members Posts: 1,671 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Engine first start, Fail.
Yesterday I made the first attempt at starting the engine since rebuild. I had put two gallons of 93 octane gas into the tank and the pump runs as it should when turning the key. I had a timer ready to perform the 20 minute cam break in. I was arrogant enough to believe that the engine would simply start when I finally tried it. WRONG. It caught for a few moments then died. And subsequent attempts gave no better of a response. I had turned the engine over with the coil disconnected to build up oil pressure before attempting the start. And thought I may have run the battery down some. Checking it showed 12.56v resting and 11.44 while cranking. I connected a big boat battery with jumper cables but still no start. It turns over and fires a couple times giving of puffs of exhaust, but does not catch and keep running. Pulled a FI hose and checked that I am getting gas, also pulled two plugs and they are wet with gas. I thought I may have flooded it so I put the battery charger on it and put it back in the garage. This morning I tried it again and the result was the same. It fires a couple times then just cranks. Everything is new. Cap and rotor, points condenser plug wires etc. injectors rebuilt buy Witchhunters , static timed when I put in the distributor. All new vacuum hoses, rebuilt MPS (set to 037 specs) ECU is an unknown but it worked when ran last (in ’89) all the wiring was carefully checked when installed Engine build is as follows. EA 1.7 engine built into a 2056 Using the djet FI with 2.0 parts, intake runners, throttle body, air cleaner, etc. HAM heads ported to RS+ and modified for the 2.0 runners Raby 9590 cam Guess I will start with rechecking the timing and go from there. |
914_teener |
May 30 2017, 02:03 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
It is important to know what ecu you have.
Are you saying that you have a 1.7 ecu when you said it ran fine back in 89? |
Olympic 914 |
May 30 2017, 02:54 PM
It is important to know what ecu you have. Are you saying that you have a 1.7 ecu when you said it ran fine back in 89? Yes The ECU was the same in 1973 for the 1.7 and the 2.0 it was an 037 The difference was the MPS was a 049 on the 1.7 and a 037 on the 2.0 And the TS2was a 012 on the 1.7 and a (NLA) 017 on the 2.0 with a 270 ohm ballast resistor. All that being said I pulled the plenum off and did a quickie plug of all of the holes then sunk it in the laundry tub and put air pressure to it. I did expect to find some leaks around where I duct taped the holes shut but I was looking for a new leak. And I found it... (IMG:style_emoticons/default/piratenanner.gif) As others had mentioned it is leaking around one of the tubular supports that go through the middle of the plenum. one of the top ones. I expected to find a gaping crack but until you put air to it you can't see it. Now I have to figure out how to fix it.. With my welding skills I will probably burn a hole through it so I was thinking either trying to sweat some solder in there or JB weld. Unless someone has a good 2.0 plenum they would like to offer up... Of course I will test this one before I put it on... |
Lo-Fi Version | Time is now: 20th May 2024 - 10:40 PM |
