Mirror Hole Spacing |
7TPorsh |
May 23 2017, 12:26 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
My car is in the shop and I can't get this measurement. What is the spacing between the mounting holes for the outside mirrors?
bandjoey |
May 23 2017, 03:15 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
If you're doing this for the passenger door the nuts are welded inside the door. Punch through from indide then drill carefully from the outside.
If for any other reason ..... never mind. (IMG:style_emoticons/default/biggrin.gif) |
r_towle |
May 23 2017, 07:20 PM
Custom Member Group: Members Posts: 24,570 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
30mm (1 3/16 ish)
Went and measured two bare doors, early and late....same. |
Maltese Falcon |
May 23 2017, 07:48 PM
Advanced Member Group: Members Posts: 4,636 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Gary...what bandjoey said !
Use a small punch that will slip nicely into a 6mm nut, gentle tap will do it. You will need to snap your door card (interior panel) off, and use a small hammer. Marty |
7TPorsh |
May 24 2017, 09:58 AM
I have already poked the holes on the passenger side. i am looking for some new mirrors. I am a little tired of the droopy stock look...also want something in black.
7TPorsh |
Lo-Fi Version | Time is now: 2nd May 2024 - 03:03 PM |
