Yes, it's true., Thanks to Dave Darling |
Porschef |
May 23 2017, 06:55 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
You can indeed, remove ALL the push rod tubes without dropping/lowering the engine. Did it this past weekend. The key is to remove the tubes and the rods together in any place where the rod alone would hit the console.
Yes, I did use a sealant during replacement, non hardening, as the tube's seals that I removed were pretty much done. A stiff breeze would have blown them out of their bores. I'll check them out this weekend, as I want to change the oil. On the track to eliminate oil leaks, if that is possible... (IMG:style_emoticons/default/dry.gif) Thanks to injunmort for the use of the lift. Very productive weekend. (IMG:style_emoticons/default/biggrin.gif) |
injunmort |
May 23 2017, 07:00 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
anytime, but you should also post pic of broken exhaust stud and repair. much skill and kudos. good time as well.
Hine62 |
May 23 2017, 07:04 PM
Member Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
Thank you! I also would like to see pics, but it sounds like you are done. My engine has a few stubborn seals leaking even after replacing the tubes and seals (yes I did pull the engine).
There has to be a better push rod tube seal out there! |
arne |
May 23 2017, 07:16 PM
Serial Rescuer of old vehicles... Group: Members Posts: 737 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
I've got numerous leaks in mine, so many that I'm dropping the engine on mine starting tomorrow. Push rod tube seals, oil cooler seals, valve covers, transmission output flanges seals, you name it. Hoping for a dry engine at the end, like my 911 has been.
Porschef |
May 23 2017, 07:19 PM
injunmort |
May 23 2017, 07:20 PM
the hole joe drilled with engine in the car could not have been drilled more accurately had it been jigged on a drill press. then drove it home over 2hours from here.
Porschef |
May 23 2017, 07:21 PM
Arne, check your rear main seal and that your tranny's not leaking also.
Porschef |
May 23 2017, 07:24 PM
Thanks Mort. I'll be happy to drill out any of the studs on the extra heads you've got, as long as it doesn't involve being under a car... (IMG:style_emoticons/default/smile.gif)
iankarr |
May 23 2017, 07:56 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Fun meeting you guys. Great hang.
Rand |
May 23 2017, 08:03 PM
That's a truly awesome rep of 914 guys. (IMG:style_emoticons/default/beerchug.gif)
arne |
May 23 2017, 08:57 PM
Arne, check your rear main seal and that your tranny's not leaking also. That possibility is exactly the reason I am dropping mine, rather than doing it in place. Three of the four major seals on the transaxle are already leaking (shift selector shaft, both output flanges). I can't see any reason to assume the input shaft seal is any different. Oil cooler seals and push rod tubes will be easier with the engine out too. |
injunmort |
May 24 2017, 04:34 AM
ian, dont forget the 10th. we are doing a valve adjustment cllnic
rmital |
May 24 2017, 07:54 AM
Northeast optimist Group: Members Posts: 1,946 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
ian, dont forget the 10th. we are doing a valve adjustment cllnic ...looking forward to that...as long as you do it my way (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/bs.gif) (IMG:style_emoticons/default/flag.gif) |
injunmort |
May 24 2017, 08:12 AM
ray, counting on you to do wilrods car as the tutorial
Porschef |
May 24 2017, 08:22 AM
It's your way or no way... (IMG:style_emoticons/default/pray.gif)
bretth |
May 24 2017, 08:26 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Where do you guys get together? I see most of you are in New York. I live a half hour south of Albany though my car is in jack stand mode.
Big Len |
May 24 2017, 11:05 AM
Senior Member Group: Members Posts: 1,747 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
bretth - Chester, NY seems to be a beehive of activity lately.
11tenths |
May 24 2017, 11:07 AM
Ve get too soon old, und too late schmart Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States |
Fun meeting you guys. Great hang. These are the pictures you will come to treasure, more so than the car shot postcards. (IMG:style_emoticons/default/drunk.gif) Cheers- Harry |
injunmort |
May 24 2017, 11:15 AM
an hour south of albany exit 16 off the thruway, 8 miles west in world famous orange county.
saigon71 |
May 25 2017, 05:42 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Well, if you insist Mort.... Yes, there was a pretty major delay of game when one of the exhaust studs broke during removal of the heat exchangers. Sucker snaapped off, and had to be drilled out. Here it is, with a couple increases in diameter to come. Mort has an awesome set of tools... Drilling those exhaust studs out with a hand drill is a gut wrenching experience. You nailed it - straight and true. Nice work! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 11:58 PM |
