Subaru cable shift |
mepstein |
May 24 2017, 09:23 PM
914-6 GT in waiting Group: Members Posts: 19,277 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
This company makes the parts to build a suby cable shifter. I have no affiliation and have not tried it but it does look nice. A possible alternative to the nla coldwater cable shifter.
http://zerodecibelmotorsports.com/products...mechanism-5spd/ Attached image(s) |
flmont |
May 24 2017, 10:23 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
that would be great if they made a Hydraulic kit too ..300.00 seems cheap.
mepstein |
May 25 2017, 04:07 AM
This product does not include the cables.
jd74914 |
May 25 2017, 05:47 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
By all accounts I've read, it's pretty nice and works well. The guy (whose name I'm forgetting) is an engineer from the midwest who is very active on the 818 forum and NASIOC. His 818 build is very clean with a ton of custom parts.
914forme |
May 25 2017, 09:30 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
I like, (IMG:style_emoticons/default/drooley.gif) any one need a Coldwater setup?
Chris H. |
May 25 2017, 10:40 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Dang that is VERY nice looking.
Front yard mechanic |
May 25 2017, 01:46 PM
Senior Member Group: Members Posts: 1,165 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Me |
Costa05 |
May 25 2017, 06:26 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Clean setup. Its now on my list of upgrades to do.
mepstein |
May 25 2017, 07:01 PM
Make sure they actually have them in stock. |
flmont |
May 25 2017, 07:09 PM
Now,..how much of a issue is the hydraulic system to install,..
mepstein |
May 25 2017, 07:24 PM
JRust |
May 25 2017, 08:16 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
It does look like a nice setup. I just want to hear from someone who installed it. Drove one with the cold water setup & it was much sloppier than my longer cable setup. Still a big improvement over the 901. There was a big difference in between mine & the coldwater setup though. Enough so that I wouldn't use it with my new motor. I like the cable being shorter & basically needing 2 of the same size. I'd sure consider this one if the shifting was nice, easy & tight (IMG:style_emoticons/default/driving.gif)
turnaround89 |
May 27 2017, 08:44 AM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Just emailed the gentlemen, these are available. I'm going to go ahead and order this for my subaru conversion. Just need to clarify a measurement that he needs before i place the order.
flmont |
May 27 2017, 02:44 PM
would there be a older 5 spd,trans that could be used with the 3.3 motor,.that is not hydraulic,..so,. I would only need to use the cable shift system,..???
914forme |
May 27 2017, 07:44 PM
Contacted the seller right after I posted. And yes he has them waiting on a few rod ends to show up. And Ill have a set in.
Also to answer the above question. Cable: found in all manual transmission 93-01 Impreza 1.8 and 2.2 models, and all Legacy 2.2 models. The clutch that use cable actuation are a bit weaker, and the cables are know to be an issue on high pressure pressure plates. |
jim912928 |
May 28 2017, 08:53 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
not sure why he couldn't adapt that for a 915!
flmont |
May 28 2017, 09:38 AM
914forme,...could I use a legacy trans mated to a 3.3,../ and would it be better than a 901 trans..??? Thanks
914forme |
May 28 2017, 08:21 PM
914forme,...could I use a legacy trans mated to a 3.3,../ and would it be better than a 901 trans..??? Thanks Yes, Subaru says they ill self destruct all over the place into a million pieces. But the SVX was 3580 LBS or so with out my fat ass sitting in it. And AWD, I am thinking your be fine. Reson I think that, AWD is like building a rolling dyne, things start to break, you fix one weak link and the next one breaks and on and on. This is not true with the RWD conversion. One you have 1480lbs less to pus around give or take, no AWD, and well if it is a narrow body car less tire. It will be fine, worse case is you can make one or two tires go up in smoke. (IMG:style_emoticons/default/confused24.gif) Of course if you are one of those rare people who can break everything then, well, it doesn't matter what you put in there, it will break. And yes it will be better than the 901. |
burton73 |
May 29 2017, 12:19 PM
burton73 Group: Members Posts: 3,526 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
not sure why he couldn't adapt that for a 915! After reading this thread and seeing just how clean this set up is and the fact that Cable Shifter Co has increased there price by over $200. In the time I have been dicking with my 74, I contacted the gentleman at Zero Decibel Motorsports, LLC To ask him if his set up would work for a 930 Turbo trans that is going in my 74 SBC V8 His response: Hello Robert, It would depend mostly on the mounting positions that are available. The bell crank has two through holes that match two threaded bosses on the 5 speed transmission. If these holes line up then it will work, otherwise you'd need an adapter. Thanks, Craig Zero Decibel Motorsports, LLC Bob B |
jimkelly |
May 29 2017, 05:04 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I just put this togther coldwater style but my 1990 suby trans did not have the two bungs that later models do, so I have to weld brakect to trans hanger.
https://www.youtube.com/watch?v=zE_UYPzY8Ss Attached image(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 12:43 PM |
