Subaru cable shift |
914forme |
Jun 16 2017, 10:47 AM
Just got all the parts yesterday, and I can say (IMG:style_emoticons/default/wub.gif)
They are a thing of beauty and simplicity. Minor amount of play in the bearing , not sure if it will be noticed or not. (IMG:style_emoticons/default/confused24.gif) Will compare it to the Coldwater system once I get a chance to pull it out of storage. I need to redo my shop storage system to make it easier to get to all my stuff. (IMG:style_emoticons/default/blink.gif) I think it is on the bottom of a stack. |
Jun 16 2017, 12:41 PM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I bought a couple of these with the 25% off coupons. I wanted something to throw small parts in and be easily visible without having to really organize too much. I've been filling them up with small seals, hardware, ect. I still need to do some better storage for the big stuff so I don't have to empty out bins to find parts but these have worked for me so far.
turnaround89 |
Jun 24 2017, 11:29 AM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Not to steal 914forme's thunder here, but I was able to get my Zerodecibel Bell Crank shifter setup last night .
It is a very nice setup, can't say anything bad about it. Solid craftsmanship and zero fitment issues. Went together in about 10minutes by looking at the images on the website. After a bit of adjustment in the heim joints on the MR2 shifter and at the bell crank shifter assembly I can reliably engage every gear. You can feel the gear engagement and shifting is very smooth. My 5th gear is a little tight to get into, but after the adjustment this became smoother. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-9067-1498325358.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-9067-1498325358.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-9067-1498325358.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-9067-1498325358.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-9067-1498325359.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-9067-1498325359.6.jpg) All the parts required and prices are below that I used in my cable shifter setup Toyota MR2 Shifter - $60 - ebay Custom Control Cables - $178 - 7ft in length, part number 100-4222-0084 Custom Control Cables Zero Decibel Bell Crank Shifter - $300 - ZeroDecibel MotorSports Bell Crank Shifter Parts list below is how I attached the Custom Control Cables to the MR2 shifter assembly 1/4-28 Heim Joints (2) - $9.87/piece - TruValue Hardware 3/8 Bronze Flange Bushing (2) - $3.12/piece - TruValue Hardware 1/4-20 Stainless Steel Bolt (2) - $0.85 - TruValue Hardware 1/4-20 Stainless Steel Nut (2) - $0.37 - TruValue Hardware The 7 foot control cables could be shortened by a few inches, however, with 7 feet I am able to route the cables away from the engine and attach them to the engine cradle. Still need to make the actual attachment to the engine cradle, but overall, the system works great! |
Jun 24 2017, 11:57 AM
Andrew - great write up.
I'd like to do something similar for my 915 transmission - without buying the unit from cableshift.com/PMS |
turnaround89 |
Jun 24 2017, 12:19 PM
Thanks Mepstein.
If anyone is curious on how the shifter operates, check out the video of the MR2 shifter in my car. My car is not drive-able, so this is just a dry run through each gear. Porsche 914 Cable Shifter I forgot one item that I also added to the cable shifter build: Toyota MR2 Shifter Base Aluminum Bushings - $28.00 - Twosrus.com Shifter Base Bushings These aren't a requirement for the shifter to work, but the rubber bushings in the MR2 shifter I bought were completely shot. |
JRust |
Jul 3 2017, 10:48 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I just sent him info to order this Bell Crank setup. After hearing how Turnaround99 felt about this setup. I felt good enough to take the plunge. IF it turns out to be crap I'll find you (IMG:style_emoticons/default/poke.gif) . Seriously I am excited to give it a try. Picked up an MR2 shifter although it has a short shift setup in it. I'll keep my eye's open for the stock one. It is short enough already. Still I can get everything in place with it
Sep 10 2017, 05:38 PM
Here's another, possible, shifter/linkage setup for a 914 - suby conversion.
http://www.verycoolparts.com/shifter.htm Attached thumbnail(s) Attached image(s) |
DBCooper |
Sep 10 2017, 07:32 PM
That last VeryCoolParts setup is how I did mine, too. It's just bent steel brackets in the rear instead of the bell crank, and works pretty well. I used an MR2 shifter up front which is definitely not as cool looking as that one though, got to admit.
dwillouby |
Sep 11 2017, 08:27 AM
Member Group: Members Posts: 392 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
This has most likely asked before. But anyway. Does anyone know how a cable setup would compare on a 901 to say a Jwest shifter with Tangerine linkage?
I am a cheap sob and on the fence about this decision. Thanks David |
76-914 |
Sep 11 2017, 10:53 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,496 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
See post #565. Might answer your question. http://www.914world.com/bbs2/index.php?sho...2722&st=560
Sep 11 2017, 12:22 PM
I'm wondering if I should buy this shifter and linkage and try to reconfigure for my 915 trans.
JRust |
Feb 8 2018, 03:36 PM
Just a quick bump as I plan to install my zero decipal unit on my transmission this weekend. I have some cables but not sure if they are the right length. So I will probably order new cables monday
effutuo101 |
Feb 8 2018, 07:25 PM
Advanced Member Group: Members Posts: 2,734 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
Anybody want to stop by Lemon Grove and help me get my shifter adjusted? Next stop, engine wiring and dyno.
jimkelly |
Feb 10 2018, 08:44 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
my favorite youtuber has just installed a honda rsx shifter in his 914/suby
https://www.youtube.com/watch?v=EEUvF_fxITM |
Lo-Fi Version | Time is now: 10th May 2024 - 07:49 AM |
