Dr. Evil Magical Hands, Look What he did - Guage assembly |
914werke |
May 12 2005, 09:58 AM
"I got blisters on me fingers" Group: Members Posts: 10,146 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
AHHHH thank you So if you want one you will have to deal with Dan AND supply the 911 components?
Dr Evil |
May 12 2005, 10:11 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Yup, I strictly do assembly.
Root_Werks |
May 12 2005, 11:06 AM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Rich, I few years back this kit was offered I think for around $100-150. It was basically a backing plate and face plate with instructions on how to take a 914 and 911 combo gauge to make a 904 style gauge. I have assembled a few and loved the whole package/kit idea. I have the plans thanks to Aaron Cox and this summer will be re-tooling R&D the kit to make another run of them. it will cost $$$ and I don't really plan on making any real money from it. Really just want the kit availble again. Even with buying a used 911 combo gauge and this kit, one should be able to put a 904 kit together for under $200. My goal is to offer the kit for under $150. |
May 12 2005, 12:12 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I would suggest modifying the backing plate so that the fuel gauge part can use the standard later (72+) fuel gauge modules. To do that, you drill holes in the same pattern as those used on the other two gauge modules (oil temp & oil press) but rotated around the center of the backing plate to the position for the fuel gauge module.
Finding the early gauges can be a bit of a pain, and having to de-solder and re-solder them is definitely a pain. If you make the above mod, you can use the later style bolt-in fuel gauge module. You wind up needing to use the 911 gauge housing as the housing for your new combo gauge, but that's quite easy to do anyway. --DD (Who did the above mods to his combo gauge kit.) |
Root_Werks |
May 12 2005, 01:39 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Already have it drawn into some modified plans. I don't want there to be any soldering required. |
Lo-Fi Version | Time is now: 11th June 2024 - 07:59 PM |
