911 E dizzy for early engine,, anyone had one machined for this application ? |
porschetub |
May 26 2017, 07:26 PM
Think it was Henry @ Supertech (Pelican forum guru) mentioned these work fine on an earlier motor but as I have found they need machining down to fit ,anyone done it ?
Appears the earlier cases up to 2.4 are the same size as any Bosch unit for 911/914 and Type 1 but after that they went to from 27 to 30mm body size. Have a excellent example and plan to lock out the retard on the advance plate. Think mb911 (Ben ) is planning using the same 006 unit on his motor. TIA. |
mb911 |
May 26 2017, 07:53 PM
914 Guru Group: Members Posts: 6,822 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I sent my E dizzy to Henry in trade for a recurved 2.7 dizzy for my app as the E dizzy is a smaller diameter shaft then my 2.4 case as it changed midway on the 2.4 run probably when they went to the 7r case?
porschetub |
May 26 2017, 10:33 PM
I sent my E dizzy to Henry in trade for a recurved 2.7 dizzy for my app as the E dizzy is a smaller diameter shaft then my 2.4 case as it changed midway on the 2.4 run probably when they went to the 7r case? Yes correct on the case changeover,thanks for the reply ,did Henry say it couldn't be machined to suit?. Appears to be enough material in the casting however the area where the sealing ring go's on could be an issue,will measure. |
mb911 |
May 27 2017, 06:03 AM
The 2.7 dizzy is a perfect fit for my case and the E was like throwing a hotdog down a hallway so i couldn't machine anything to work for me.
Lo-Fi Version | Time is now: 4th May 2024 - 07:55 AM |
