Calwaterbear |
Member ![]() ![]() Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California ![]() |
Ok time to set-up my new/used 2 post lift. I poured a 14'X 25' pad, let it cure for 3 weeks.
So I will drill into the concrete and use 3/4 X 10'' wedge anchors. they will be 8" deep. obviously the holes need to be drilled in exactly the right places, not only for each post, but also, the 2 posts have to be set at the exact width (dictated by the bar across the top, between the 2 posts). so do i set up the posts, bolt on the top, then drill down through the feet? Or use a template, put in the anchors, then drop the posts onto the anchors? Bit of an issue is i am working alone, and even with a bobcat 763, i have not figured out a way to get the posts vertical yet, i plan on calling in my propane guy, who has a real live Ferrari crane on his service truck to lift em upright and position them. Tech guys at Greg Smith say to drill the holes a couple of inched deeper than you will be anchoring at - so if you screw up, instead of having to cut off the anchor - you just drive it down in the slab. That seems like a good idea, but what if, while lowering the post, you miss and hit the top of the anchors, that would probably drive them down into the slab - No? I'm probably overthinking this, but I'm hoping to draw from the experience of others who have gone before me on this venture! |
Lo-Fi Version | Time is now: 15th July 2025 - 04:31 AM |
