FS SSS Super Shiny Stuff |
bdstone914 |
May 29 2017, 09:19 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Steel Early type Gas Caps $30 Four available. New seals will be included.
Hold down plate and bolt for spare tire $30 Two or more sets. Near Perfect sets. Fuel Rails and injector hold down set of 6 parts $40. Two or more correct sets. Several more with both rails having pressure test ports. It is reported the a test port on the Passenger side can interfere with the MPS mounting. Controlled by size and shape of the elbows on the fuel injectors to fuel rails. Voltage regulator Covers. $15 each , 6 available. Replated clear zinc. There are some imperfections in plating where the wires were wrapped around them. Various markings on the tops. Pain in the butt to clean and polish. Attached thumbnail(s) |
Bartlett 914 |
May 29 2017, 01:24 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Steel Early type Gas Caps $30 Four available. New seals will be included. Hold down plate and bolt for spare tire $30 Two or more sets. Near Perfect sets. Fuel Rails and injector hold down set of 6 parts $40. Two or more correct sets. Several more with both rails having pressure test ports. It is reported the a test port on the Passenger side can interfere with the MPS mounting. Controlled by size and shape of the elbows on the fuel injectors to fuel rails. Voltage regulator Covers. $15 each , 6 available. Replated clear zinc. There are some imperfections in plating where the wires were wrapped around them. Various markings on the tops. Pain in the butt to clean and polish. I would like a gas cap |
Lo-Fi Version | Time is now: 17th May 2024 - 04:39 PM |
