Front wheel bearing get loose too often, 30,000 miles since new, seem to loosen every year |
second wind |
May 29 2017, 11:09 AM
Senior Member Group: Members Posts: 855 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Happy Memorial Day.....my wheel bearings seem to loosen up far too often. I replaced less than 30,000 miles ago and when i tighten them back up I allow wheel to spin freely but with a touch of drag. Any thoughts on what is going on? Thank you!
g |
toolguy |
May 29 2017, 11:19 AM
Ft wheel bearing should be the most maintenance free item on your car. . really can't loosen up except for ball / race wear or if the pinch nut wasn't tightened properly .
Since you said you replaced the bearings recently, how sure are you that you fully seated the new inner race. . . ?? that's the 1st place to look. . then clean the bearings and look for obvious wear. . do both side do the same |
second wind |
May 29 2017, 11:33 AM
Please discuss "pinch nut tightened properly". Maybe I am not tightening against the bearing enough? Thank you very much!
gg |
May 29 2017, 12:46 PM
The front wheel bearings will loosen up with hard use. We used to see that all the time at autocrosses--about once a season, the 914s would need their front wheel bearings re-tightened.
The spec for the bearings is literally "tight enough that the washer behind the nut can just barely be moved with the tip of a screwdriver." --DD |
Lo-Fi Version | Time is now: 17th May 2024 - 02:56 PM |
