914-6 Conversion |
914-6 Conversion |
Coloradocurt |
Jun 2 2017, 02:55 PM
Member Group: Members Posts: 65 Joined: 20-November 16 From: Castle Rock, Colorado Member No.: 20,603 Region Association: Rocky Mountains |
On a 914-6 conversion which will be running headers (instead of heat exchangers), (1) are there covers available to block off the outlets from the engine cover for the heater flex-tubes which would be used if there were going to be heat exchangers, and (2) covers to close off the holes in the engine tin on both sides where those flex hoses would be routed down to the heat exchangers?
And an alternative on that 2nd question, is anyone offering those engine tin with no holes for a much cleaner application? Thanks, Curt |
Jun 2 2017, 05:44 PM
Most of the conversion tin does not have the holes for the heat like the factory tin. It sounds a little cheesy but caps from spray cans fit really well on the outlets. A hose clap keeps them tight. You really don't see it when the engines in. Paint them body color if you really want them to disappear. You can get fan tin without an outlet for heat. Pelican sells it.
TravisNeff |
Jun 2 2017, 07:19 PM
patssle |
Jun 2 2017, 07:55 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Spend $100 or make your own cap. I made my own...see in background. Piece of metal with sides folded down and metal tape wrapped around it.
porschetub |
Jun 3 2017, 01:30 AM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Yes but the RH one fits really badly ...got suckered ,HUGE waste of money.they said send it back....real handy when you are half a world away (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) . Yes you can just block off the outlets but there are gains in cooling by fitting the right blockoff's. |
TravisNeff |
Jun 3 2017, 01:56 PM
Hmm mine seem ok. One needs a touch of trimming.
wndsnd |
Jun 4 2017, 12:58 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Most of the conversion tin does not have the holes for the heat like the factory tin. It sounds a little cheesy but caps from spray cans fit really well on the outlets. A hose clap keeps them tight. You really don't see it when the engines in. Paint them body color if you really want them to disappear. You can get fan tin without an outlet for heat. Pelican sells it. I second the spray can caps. Cut bottom third off and push in. Touch up with undercoat or body color. Fit perfectly. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:00 PM |
