On a 914-6 conversion which will be running headers (instead of heat exchangers), (1) are there covers available to block off the outlets from the engine cover for the heater flex-tubes which would be used if there were going to be heat exchangers, and (2) covers to close off the holes in the engine tin on both sides where those flex hoses would be routed down to the heat exchangers?
And an alternative on that 2nd question, is anyone offering those engine tin with no holes for a much cleaner application?
Thanks,
Curt
