Acquired!, Gateway Porsche Audi License Plate Frame |
914_7T3 |
Jun 4 2017, 06:58 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Tom_T |
Jun 4 2017, 10:21 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Jeffrey,
If you can't locate a nice set, then you can probably restore them by stripping, filling divots, rechroming & repainting them/it. For the divot filling, you can get an "Aluminum Welding Kit" from Vintage Trailer Supply which is essentially pot-metal like the frames are made of, & you use a small pencil blowtorch to fill in any rusted holes, then sand to smooth with 400 - 1000 grit - then off to the chrome shop, then paint after chroming (make sure to match paint colors before stripping). http://www.vintagetrailersupply.com/Alumi-...t-p/vts-335.htm PS - It's a little trick from one of my other hobbies - restoring the cast metal chromed pieces on our 1960 Avion T20 trailer (like an Airstream). Good Luck Hunting or Restoring! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
914_7T3 |
Jun 5 2017, 10:37 PM
Jeffrey, If you can't locate a nice set, then you can probably restore them by stripping, filling divots, rechroming & repainting them/it. For the divot filling, you can get an "Aluminum Welding Kit" from Vintage Trailer Supply which is essentially pot-metal like the frames are made of, & you use a small pencil blowtorch to fill in any rusted holes, then sand to smooth with 400 - 1000 grit - then off to the chrome shop, then paint after chroming (make sure to match paint colors before stripping). http://www.vintagetrailersupply.com/Alumi-...t-p/vts-335.htm PS - It's a little trick from one of my other hobbies - restoring the cast metal chromed pieces on our 1960 Avion T20 trailer (like an Airstream). Good Luck Hunting or Restoring! (IMG:style_emoticons/default/beerchug.gif) Tom /////// Thanks for the detailed info Tom. However, I do not even have one to work on so maybe one will come along. |
Lo-Fi Version | Time is now: 20th May 2024 - 03:26 PM |
