Snorkle w/ Harness Installation step, by step., 72 Restoration Project |
Garland |
Jun 6 2017, 09:57 PM
Restoration Fanatic Group: Members Posts: 1,328 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
First I wanted to include this from SirAndy
This is from my 72 restoration project. Here is the way I installed my wire harness. Step by step. Remove plastic guide tube . Must move this conector through the hole, the harness is to stiff to do this step later |
Mikey914 |
Jun 6 2017, 10:25 PM
The rubber man Group: Members Posts: 12,647 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Very nice car porn (IMG:style_emoticons/default/biggrin.gif)
Garland |
Jun 6 2017, 10:29 PM
Thank you |
barefoot |
Jun 7 2017, 06:37 PM
Senior Member Group: Members Posts: 1,270 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Here is the way I installed my wire harness. Step by step. these photos show a black tube inserted from the tunnel to back thru the firewall. Is this a part of the harness, or a separate rubber or plastic tube just used to help feed wires thru ?? If so what size ? |
Garland |
Jun 7 2017, 07:22 PM
Just a black plastic large cord holder, with the slip down the side . Its only to protect and guide the harness.
barefoot |
Jun 7 2017, 08:32 PM
Garland;
Thanks for quick response, good stuff !! |
Matty900 |
Jun 8 2017, 10:40 PM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
Figured out today that you can cut off the end of the 914Rubber Snorkel tube to use as the wiring harness grommet in to the front trunk. Early uses on end, late uses the other end (IMG:style_emoticons/default/w00t.gif)
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 1st May 2024 - 08:59 AM |
