any simple solutions to through hood gas fill?, anyone add links or pics of a diy through hood gas fill? |
funk |
Jun 8 2017, 07:41 PM
Member Group: Members Posts: 100 Joined: 23-June 14 From: sandpoint idaho Member No.: 17,531 Region Association: Pacific Northwest |
I not only like the look of this mod but adds simplicity to gas fill ups the only negative from my perspective is now gas entry is not protected?
so any one have measurements and close up pics? I am assuming that it is more than just a hole. also probably a ring is welded on hood so as to give a relief even added seal? I think Patrick motorsports has pics in their gallery? |
burton73 |
Nov 11 2017, 02:01 PM
burton73 Group: Members Posts: 3,508 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Peter Dawes did the fuel on number 41 a long time ago. The fuel door is from an airplane.
“California knows how to party” Bob B |
jd74914 |
Nov 11 2017, 02:56 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
burton73 |
Nov 12 2017, 04:16 PM
Peter Dawes did the fuel on number 41 a long time ago. The fuel door is from an airplane. Bob-your filler is so cool! It's such a novel install using the camloc fasteners. It is not really Camloc fasteners but you push one button down the second button goes up and the door opens. There is an arm inside and pushing the second button down make it pressure lock. The unlock is engraved open, and the loch is marked close. If I remember it right I have not touched it for 5 years. It is not just a hinge but has a spring arm and a hinge. The PO had it up and tried to open the front hood and bent it up. E's body man fixed it up. NEW RULE Never open the hood when the gas cover is open. Bob B |
jd74914 |
Nov 13 2017, 08:34 AM
It is not really Camloc fasteners but you push one button down the second button goes up and the door opens. There is an arm inside and pushing the second button down make it pressure lock. The unlock is engraved open, and the loch is marked close. If I remember it right I have not touched it for 5 years. It is not just a hinge but has a spring arm and a hinge. The PO had it up and tried to open the front hood and bent it up. E's body man fixed it up. NEW RULE Never open the hood when the gas cover is open. Bob B Interesting. I was wondering why there were two buttons. Do you have any photos of the back side? I can envision how it works from your description, but the hardware is interesting-never seen anything quite like that. |
Lo-Fi Version | Time is now: 29th April 2024 - 11:07 AM |
