autocross and a hot day, crane ignition quit - what is better? |
worn |
Jun 12 2017, 10:41 AM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
We are having unseasonably hot weather here. Doug and I headed for the autocross yesterday and while the oil temp and head temps were within reason, that engine bay was too hot to touch. And then no spark. Has happened before. I think the failure point was the photodetector for the Crane Fireball ignition module.
I have had enough. It is either points or something electronic I can trust. I generally carry a spare dizzy, but it was at home yesterday... So - can anyone point me to the most reliable system? I am not wild about changing points, so I would prefer something electronic. Thanks again Brain Trust! |
Porschef |
Jun 12 2017, 10:59 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Hey Warren,
Lots of different opinions regarding Pertronix, but I've been running a unit for about 4 years with no issues. Joe |
cary |
Jun 12 2017, 09:45 PM
Been on my car 13-14 years
JeffBowlsby |
Jun 13 2017, 07:52 AM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
20 years of running points, 10 of those as a daily driver, never let me down.
worn |
Jun 13 2017, 08:16 AM
20 years of running points, 10 of those as a daily driver, never let me down. Yeah - I know. But you be a stickler for the wiring. Thinking of pertronix backed up with a gapped distributor and points in the trunk. Turned out to be useful last year at Rt 66. |
ConeDodger |
Jun 13 2017, 08:28 AM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Points. Done right, the most reliable analog system.
mskala |
Jun 13 2017, 08:29 AM
QUOTE I think the failure point was the photodetector for the Crane Fireball ignition module. I use the Crane LED/Detector, though I don't use the Crane box. The part that's in the distributor is literally only and LED and a photodiode and a plastic holder. I've had this one for at least 5 years with no issues. Before that on my other engine, I had made one with a random old radio shack LED and photodiode which gave no trouble for 10 years. I would think if there's a problem related to the trigger it's either a wiring fail or the box that drives the LED and receives the signal. |
worn |
Jun 13 2017, 03:53 PM
QUOTE I think the failure point was the photodetector for the Crane Fireball ignition module. I use the Crane LED/Detector, though I don't use the Crane box. The part that's in the distributor is literally only and LED and a photodiode and a plastic holder. I've had this one for at least 5 years with no issues. Before that on my other engine, I had made one with a random old radio shack LED and photodiode which gave no trouble for 10 years. I would think if there's a problem related to the trigger it's either a wiring fail or the box that drives the LED and receives the signal. So what do you use downstream of the photodiode/LED pair? |
mskala |
Jun 13 2017, 04:09 PM
So what do you use downstream of the photodiode/LED pair? I simple circuit to put power to LED and buffer the receiver and it just goes to (911) Bosch CD box. Pelican - how-i-use-crane-optical-trig-bosch-cdi-3-pin BTW it was 95 degrees at my autocross sunday. |
worn |
Jun 13 2017, 05:26 PM
So what do you use downstream of the photodiode/LED pair? I simple circuit to put power to LED and buffer the receiver and it just goes to (911) Bosch CD box. Pelican - how-i-use-crane-optical-trig-bosch-cdi-3-pin BTW it was 95 degrees at my autocross sunday. Damn, I am tracing trouble with my 911 CD box too, but still in my 1980 911! Been off and on for 10 years or more. I finally think I have found the problem at the green trigger wire from the reluctor coil... Wish me luck. I have a couple of MSD 6AL units on hand. Are they dependable once I change out the Behru wires? And if so, can I keep the Behru spark plug connectors with carbon wrapped wires? I know. More questions. I made an aluminum chopper for the photosensor with the Crane unit. The box was too hot to touch, but maybe my chopper sawed away at the photosystem. Will find out soon. Thanks!! |
porschetub |
Jun 13 2017, 06:28 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
We are having unseasonably hot weather here. Doug and I headed for the autocross yesterday and while the oil temp and head temps were within reason, that engine bay was too hot to touch. And then no spark. Has happened before. I think the failure point was the photodetector for the Crane Fireball ignition module. I have had enough. It is either points or something electronic I can trust. I generally carry a spare dizzy, but it was at home yesterday... So - can anyone point me to the most reliable system? I am not wild about changing points, so I would prefer something electronic. Thanks again Brain Trust! Researched till me eyes bleed,purchased a 75MY Permatune,they are very reliable units and last well,the Bosch units are generally less that way,teamed mine up with Pertronix II system and then found the pertronix coil for that CDI won't give optimum performance,purchased a NOS Permatune transformer coil off ebay for a song ...these are expensive if you don't shop well. My car on carbs starts straight up and runs really nice,think I have the ignition pretty well covered,however without Bob @ashlocktech I way totally uneducated,Pertronix don't really supply the right installation instructions...oh by the way buy good leads,Clewitt make the best IMO. Good luck. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:45 PM |
