peteyd |
Senior Member ![]() ![]() ![]() Group: Members Posts: 737 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada ![]() |
Hey was wondering if anybody could help me out ? I had a running car which started fine, we ran out of gas now it won't start. I checked the plugs, all kinds of fire, when I the pulled plugs out they were wet .then checked coil in distributor it reads 12.6 volt.. so took all plugs out checked compression cylinder 1 100psi cylinder 2 90 psi cylinder 3 90psi cylinder 4 70psi..is this to low or fine ?checked fuses they all look good. just got car on road and she dies
thanks in advance hoping it don't need rebuild .. Pete |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,192 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Compression looks good. Wet plugs are never a good sign. What type of induction? FI or carbs?
Squirting some starting fluid into the intake can indicate if the electrics and timing is ok. Points or electronic ignition? |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Is this the yellow car again?
The 70 on #4 is low, but a compression check on a cold engine doesn't mean much. |
peteyd |
This has the original fuel injection.
1974 2.0L d-jet Mark, it is the yellow car. We are still using the points, but we have a dizzy with the pertronix here. That was suppose to be your replacement though Mark. |
peteyd |
peteyd |
Compression looks good. Wet plugs are never a good sign. What type of induction? FI or carbs? Squirting some starting fluid into the intake can indicate if the electrics and timing is ok. Points or electronic ignition? its fuel injected it has points |
Keith914 |
Member ![]() ![]() Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California ![]() |
Running empty may have dislodged dirt in your fuel tank which is now blocking sufficient flow.
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,967 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
maybe try to check fuel pressure.
peteyd |
I am certain it is getting fuel. The plugs are getting wet and its also getting a great spark.
maybe timing? |
Mark Henry |
Mark, it is the yellow car. We are still using the points, but we have a dizzy with the pertronix here. That was suppose to be your replacement though Mark. No problem if you want to try swapping them around, but unless you burned out the points, by leaving the ignition on, I don't think that's the issue. Would it quit (cut out and then back on) while driving? Often that can be the big hose under the fuel tank is kinked almost closed, then after driving the pump will suck it right closed resulting in the engine dying till it opens back up. Take the rack protection plate off and there's an access hole you can stick you hand in and feel the hose for kinks. I run a hose off a fuel rail and duct tape a pressure gauge to the rear window, then take the car out for a spin at hwy speeds. If you have any kind of pressure loss this will tell you PDQ. You do have the transmission ground strap installed right? Make sure that all grounds have no body paint under the connections. |
peteyd |
Mark, it is the yellow car. We are still using the points, but we have a dizzy with the pertronix here. That was suppose to be your replacement though Mark. No problem if you want to try swapping them around, but unless you burned out the points, by leaving the ignition on, I don't think that's the issue. Would it quit (cut out and then back on) while driving? Often that can be the big hose under the fuel tank is kinked almost closed, then after driving the pump will suck it right closed resulting in the engine dying till it opens back up. Take the rack protection plate off and there's an access hole you can stick you hand in and feel the hose for kinks. I run a hose off a fuel rail and duct tape a pressure gauge to the rear window, then take the car out for a spin at hwy speeds. If you have any kind of pressure loss this will tell you PDQ. You do have the transmission ground strap installed right? Make sure that all grounds have no body paint under the connections. Alright we got 'er! we gapped the plugs better and made sure some of the injection wiring was tight. some of it seemed too loose. thanks for all the help Pete |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,200 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I am certain it is getting fuel. The plugs are getting wet and its also getting a great spark. Getting fuel isn't the same as getting proper fuel pressure. Wet plugs don't like to fire. Once you cleaned them off, does it now fire? Once you know you have some fuel, you have good spark, and you have some compression, there are only two more things that would cause a no-start. Timing is one, but it would have to be way off. The amount of fuel is the other. It's not that hard to bump an electrical connection or a vacuum line off and throw the mixture out of whack to the point where it won't start. (E.g., CHT sensor connector unplugs, hose from the MPS gets unplugged, etc.) So you check all of your wires and hoses. Many vacuum leaks won't prevent a D-jet car from starting, but there are a lot of electrical connections that can. --DD |
peteyd |
I am certain it is getting fuel. The plugs are getting wet and its also getting a great spark. Getting fuel isn't the same as getting proper fuel pressure. Wet plugs don't like to fire. Once you cleaned them off, does it now fire? Once you know you have some fuel, you have good spark, and you have some compression, there are only two more things that would cause a no-start. Timing is one, but it would have to be way off. The amount of fuel is the other. It's not that hard to bump an electrical connection or a vacuum line off and throw the mixture out of whack to the point where it won't start. (E.g., CHT sensor connector unplugs, hose from the MPS gets unplugged, etc.) So you check all of your wires and hoses. Many vacuum leaks won't prevent a D-jet car from starting, but there are a lot of electrical connections that can. --DD I believe it was the CHT sensor connector. that is the white wire correct? |
Most of the FI stuff has white wires. If you mean a single white wire near the #3 spark plug, then yes. It's the CHT sensor, and knocking it loose will result in a no-start. And when you spend 3 hours in the parking lot at work trying sixty-five different things only to realize that it was one simple f***ing wire that you accidentally knocked loose, you'll feel pretty dumb. Especially after several of your coworkers mock you on your way home...
Uhhh, not that I know that from experience or anything.... (IMG:style_emoticons/default/wink.gif) --DD |
KeithVonLaws |
Member ![]() ![]() Group: Members Posts: 57 Joined: 19-July 16 From: Napoleon , Ohio 43545 Member No.: 20,205 Region Association: North East States ![]() |
Sounds like a CHT Issue to me... I have had the same problem in the past myself.
If you hook your Ohm meter to it you should have about 2500 Ohms at 68 degrees F. If you get a reading significantly higher than 2500 Ohms like I did the computer will command more fuel. If it is unplugged it will think it is -40 degrees F . And dump as much fuel as it can. You will likely need to change your oil too.... Good Luck |
Lo-Fi Version | Time is now: 13th July 2025 - 10:42 AM |
