1 More ignition switch question, '73 and '74 compatibility |
Chris H. |
Jul 2 2003, 02:43 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
OK I promise this will be the last dumb ignition switch question for a while.
Does a '73 ignition switch (the whole metal cylinder with the key hole that bolts to the column) fit into a '74 car? I think the answer is yes, but I'm not positive. Sorry to bother you all, but I know you will know.... Thanks again everyone. Chris H. |
tryan |
Jul 2 2003, 02:57 PM
Senior Member Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 |
can you check the part #'s on pelican to see if they are the same?
Aaron Cox |
Jul 2 2003, 03:56 PM
im 98 % sure they are the same, i think they changed the design in 75 (IMG:style_emoticons/default/splat.gif)
TheCabinetmaker |
Jul 2 2003, 04:02 PM
I'm 99% sure the answer is yes. they were changed in 75. 70-72 same. 73-74 same.75-76 same.
Lo-Fi Version | Time is now: 20th May 2024 - 05:21 AM |
