Chris H.
Jul 2 2003, 02:43 PM
OK I promise this will be the last dumb ignition switch question for a while.
Does a '73 ignition switch (the whole metal cylinder with the key hole that bolts to the column) fit into a '74 car? I think the answer is yes, but I'm not positive. Sorry to bother you all, but I know you will know....
Thanks again everyone.
Chris H.
tryan
Jul 2 2003, 02:57 PM
can you check the part #'s on pelican to see if they are the same?
Aaron Cox
Jul 2 2003, 03:56 PM
im 98 % sure they are the same, i think they changed the design in 75
TheCabinetmaker
Jul 2 2003, 04:02 PM
I'm 99% sure the answer is yes. they were changed in 75. 70-72 same. 73-74 same.75-76 same.
