Wtb, 914-8 5.7 |
Wtb, 914-8 5.7 |
sb914 |
Jun 18 2017, 06:15 AM
Surf Guru Group: Members Posts: 4,298 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
914-8 5.7 badge maybe someone has one in there stash.
Tom_T |
Jun 18 2017, 01:13 PM
There was a member or 2 on here making custom CNC cut badges on here, who can probably do on for you, assuming that they're still making them now.
You'll have to get the mounting studs welded on them, or else use body trim adhesive. Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
ValcoOscar |
Jun 18 2017, 01:46 PM
Garage Life Group: Members Posts: 2,383 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
If you have one made I can tig weld studs as Tom suggested.
Perhaps make a second, my buddy is working on his 914 V8. Shoot me cost if you find source. Thanks |
sb914 |
Jun 18 2017, 03:51 PM
There was a member or 2 on here making custom CNC cut badges on here, who can probably do on for you, assuming that they're still making them now. You'll have to get the mounting studs welded on them, or else use body trim adhesive. Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// I tried with member here making them,but the thread is a year old So he prob won't be making them! Oscar I'll let you know if I source. Thanks |
euro911 |
Jun 19 2017, 11:39 PM
There was a member or 2 on here making custom CNC cut badges on here, who can probably do on for you, assuming that they're still making them now. I tried with member here making them,but the thread is a year old You'll have to get the mounting studs welded on them, or else use body trim adhesive. Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// So he prob won't be making them! Oscar I'll let you know if I source. Thanks http://www.914world.com/bbs2/index.php?s=&...t&p=2498424 |
Mueller |
Jun 20 2017, 08:21 AM
There was a member or 2 on here making custom CNC cut badges on here, who can probably do on for you, assuming that they're still making them now. I tried with member here making them,but the thread is a year old You'll have to get the mounting studs welded on them, or else use body trim adhesive. Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// So he prob won't be making them! Oscar I'll let you know if I source. Thanks http://www.914world.com/bbs2/index.php?s=&...t&p=2498424 thanks for the plug Mark, I sent Eddy a PM. The adhesive would be my choice, but if we knew the spacing you want , the studs can be done as well. The ones in the picture are .125" thick, however I can make them thicker if you want, and change the scale so they are smaller or larger than the standard 20mm height. |
Lo-Fi Version | Time is now: 8th May 2024 - 05:37 PM |
